3D-Coat V3 for Linux (beta)
10 posts in this topic
There you can download V3 for Linux
www.3d-coat.com/~sergyi/3D-Coat-V3-BETA.tar.gz
It will work only for 64-bit Linux (32 bit will be later). Unpack it to your user folder like /home/"user_name"
Transferring rules will be published soon.
EDIT: It is better to use swap file to avoid instability on insufficient memory.
How to manage swap files under Linux.
Show your swap files with Terminal command
swapon -s
If the list is empty you should create swap file with Terminal commands
sudo dd if=/dev/zero of=/swapfile bs=1M count=4000 (or whatever size you want in megabytes)
sudo mkswap /swapfile
sudo swapon /swapfile
This is great! My dream came true!
swapon -s
Thank you Andrew and Sergej for making this possible.
i'll give it a try as soon as a 32bit version is out since I want
to work more on openartist linux (ubuntu) http://www.openartisthq.org
but openartist is only 32bit, so I have to wait ab it ;)
Hi Andrew
couple of bugs so far:
- 'show info' is not displayed
- if I increase resolution twice on standard sphere in voxel mode, 3d-coat crashes
- All surface tools in voxel mode make 3d-coat crash
I'm on holiday atm so have not gone too far in depth yet
my specs
linux mint x64
dual core 2.4
quadro fx1600 m
4 Gb ram
2Gb swap
This is wonderful :yahoo:
I was able to run 3DC under fedora after I created a simlink from libtiff.so.3 to libtiff.so.4
A bug that wasn't mention yet
- run 3DC from a console
After you put in the key, 3DC closes. In the console it shows that 3DC tried to run 3dcoatGL.exe
The web page shows that registration was completed but 3DC stays in trial mode
FEDORA 11 64-bit
i7 920
12 GB RAM
GeForce GTX 280
2x Opteron 270
8 GB RAM
GeForce 7 GS
