Member probiner Posted February 6, 2010 Member Report Share Posted February 6, 2010 Maybe i'm doing something worng... But it seems that 3D-Coat spacing is not nice for sharp strokes and if if turn spacing it gets very noisy like in the image below and also very very slow. A faster and lessy noisy stroke with good spacing would be great, as it essential in many painting works to take the most vantage of the brush qualities (not the particular case in the image, but just to exemplify the noise) Cheers Quote Link to comment Share on other sites More sharing options...
Member probiner Posted February 7, 2010 Author Member Report Share Posted February 7, 2010 For someone that uses photoshop to paint this kind of clean stroke is important(no visible samples). Possible in 3D-Coat with nice performance? Cheers Quote Link to comment Share on other sites More sharing options...
Member probiner Posted February 7, 2010 Author Member Report Share Posted February 7, 2010 So... no way to do a stroke like that in 3D-Coat? Cheers Quote Link to comment Share on other sites More sharing options...
Advanced Member akira Posted February 8, 2010 Advanced Member Report Share Posted February 8, 2010 So... no way to do a stroke like that in 3D-Coat? Cheers Hope this helps: http://www.3d-coat.com/forum/index.php?showtopic=1657&view=findpost&p=10591 Quote Link to comment Share on other sites More sharing options...
Member probiner Posted February 8, 2010 Author Member Report Share Posted February 8, 2010 It does. Thank you. Still slow, but my machine specs also have influence there, and the end result is the intended one. Andrew's brush works fine, since it's stretch along the array. Only problem i see now is with the alpha when color is added in the color channel. In some other brushes the alpha gets holes and in the crossings gets black halo. In the image you see only the black soft halo. Cheers Quote Link to comment Share on other sites More sharing options...
