Followers 0
Taros
Retopo room: Switch between transparent and solid mesh view
4 posts in this topic
Hello.
In the retopo room currently you see the transparent version of your retopo result, what is really good for retopo work. No critiqes here.
But I would like to switch the transparency off, often. I would like to see a "regular view" of my retopo mesh to check the mesh surface.
Important too: To have the possibility to switch the wires off, if needed.
Best wishes
Chris
Hello.
Best wishes
Chris
Add to this Gouraud Shading and a live subdivision preview, and it would be totally awesome.
A subdivision preview would kill the workflow. It is only interesting, after Andrew have implemented a multicore support for the retopo tab - as long as this is not solved, a subdivision preview will need too much cpu time and is currently not practicable.
Why do you need a subdivision preview? Give an example.
When you want to have a non subdevided object for say, cinematics. You want the base mesh to be very low polygon and increase the sub-ds as the camera gets closer. you care less about how the base polygon mesh looks but want the sub-ds to look good.
This also applies to hard surface modeling. Have a very low base mesh.
Followers 0
