Taros Posted June 4, 2010 Report Share Posted June 4, 2010 Is that like over 22x speed up. That's quite amazing. Andrew, could you fix my car (volvo). umpf... yep... that's right... oh dear. Have worked to much, I guess. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted June 4, 2010 Contributor Report Share Posted June 4, 2010 Just tried caching a 16mil layer to level 3 (x8) and used Big move brush radius for quite a few strokes and merging time was below 4 minutes. Strokes with such a big radius like that would have generated at least 1 hour of merging time in previous way. Huge noticable improvement.Transfer of changes done to proxy is very impressive. Quote Link to comment Share on other sites More sharing options...
Member amcmahon Posted June 4, 2010 Member Report Share Posted June 4, 2010 Export Object from voxtree is broken,Andrew tried to fix it but it didnt work. To get matching scale with retopo export you need to export your voxel object using either Export Scene or Export Pattern from voxtree. (don't worry,export pattern works exactly like a normal export...you even get decimation control ) Sweet. Thanks Artman, it worked. Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted June 4, 2010 Advanced Member Report Share Posted June 4, 2010 Just tried caching a 16mil layer to level 3 (x8) and used Big move brush radius for quite a few strokes and merging time was below 4 minutes. Strokes with such a big radius like that would have generated at least 1 hour of merging time in previous way. Huge noticable improvement.Transfer of changes done to proxy is very impressive. Artman, there are no transfer of changes. Editing the proxy has no effect on the main object. When you toggle the cache button the original object will be reloaded and changes to the proxy will be lost. Quote Link to comment Share on other sites More sharing options...
Javis Posted June 4, 2010 Report Share Posted June 4, 2010 Artman, there are no transfer of changes. Editing the proxy has no effect on the main object. When you toggle the cache button the original object will be reloaded and changes to the proxy will be lost. I'm having this happen too. It wasn't happening at all before for hours of testing. Now it wont work and has the above results. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted June 4, 2010 Report Share Posted June 4, 2010 Wait, am I understanding that some people are seeing changes made to the cache proxy get applied to the high res model? In all of my testing so far I've never seen that happen. Quote Link to comment Share on other sites More sharing options...
Javis Posted June 4, 2010 Report Share Posted June 4, 2010 Wait, am I understanding that some people are seeing changes made to the cache proxy get applied to the high res model? In all of my testing so far I've never seen that happen. Yep, that's the idea. It was working for me. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted June 4, 2010 Report Share Posted June 4, 2010 Well if that's the way it worked I'd be very impressed, it never did that for me so I had no idea. Quote Link to comment Share on other sites More sharing options...
Javis Posted June 4, 2010 Report Share Posted June 4, 2010 I was messing with 3.3.02 before it was released, for about 2 hours, and had no issue with it. Unsure why it's not working now... Hmm. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 4, 2010 Reputable Contributor Report Share Posted June 4, 2010 It was not working as described for me either on Win32 bit non_cuda 3.3.02. Linux version has not been updated to 3.3.02 yet... Anyway, part of Andrew's quote a few post up is exciting news. Quote: "I absolutely agree that multiresolution will be more then useful. And it will be logical next step. Caching is just first step to this long-long-waiting direction. I hope multiresolution will be there until 3.4 (but I can't promise, all depends on how successfull experiments will be): " Quote Link to comment Share on other sites More sharing options...
Javis Posted June 4, 2010 Report Share Posted June 4, 2010 He mentioned that to me the other night when I got to test out the caching, you can logically see how caching is leading to multi-res. I am pretty excited about that. It should change 3DC quite a bit, at least in the way we use it for voxel sculpting. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 4, 2010 Reputable Contributor Report Share Posted June 4, 2010 I wonder if there is a way to use a variant of the Surface Freeze tool, to paint areas we know we don't plan to work on, and have that painted area merge in the background (so the user doesn't have to stop and wait), and save to cache. That way, the only thing that gets calculated when you are ready to move back to Voxel Volume, is that area you worked on. By the way, Andrew just fixed a bug with the Split Tool (it wasn't working at all, just showing an empty volume), and he said he reloaded the build with the fix...in case anyone needs to use it. Quote Link to comment Share on other sites More sharing options...
Contributor artman Posted June 4, 2010 Contributor Report Share Posted June 4, 2010 Artman, there are no transfer of changes. Editing the proxy has no effect on the main object. When you toggle the cache button the original object will be reloaded and changes to the proxy will be lost. I was talking about transfer time of changes done in surface mode back to voxel mode when using large brush strokes on the proxy. Of course,getting the hires somehow displaced by the proxy is obviously the next step. Quote Link to comment Share on other sites More sharing options...
Advanced Member geo_n Posted June 5, 2010 Advanced Member Report Share Posted June 5, 2010 Artman, there are no transfer of changes. Editing the proxy has no effect on the main object. When you toggle the cache button the original object will be reloaded and changes to the proxy will be lost. I thought the workflow was to edit the proxy model with big brushes that will translate to the original voxel as well. But yeah reverting to original voxel makes all edits to proxy object vanish. wierd. Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted June 5, 2010 Advanced Member Report Share Posted June 5, 2010 I was talking about transfer time of changes done in surface mode back to voxel mode when using large brush strokes on the proxy. Of course,getting the hires somehow displaced by the proxy is obviously the next step. Well of course it's fast because it's a low res object. Switching from Surface to Voxel mode has always been fast with low res objects. I dunno, reading some of the recent posts I'm getting the impression some people don't realize that it has always been possible to lower the resolution of the default voxel sphere. So if anybody wants high speed shaping then just lower the resolution of the voxel space using 'Clone and Degrade' in the layer menu, then delete the original layer. Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted June 5, 2010 Advanced Member Report Share Posted June 5, 2010 I thought the workflow was to edit the proxy model with big brushes that will translate to the original voxel as well. But yeah reverting to original voxel makes all edits to proxy object vanish. wierd. Andrew never stated that this was the case, the purpose of the proxy is simply to conserve memory. But it's easy to see why some people are getting confused. But it's okay, Andrew has said that he plans to make the changes to proxy transfer over. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted June 5, 2010 Report Share Posted June 5, 2010 Andrew never stated that this was the case, the purpose of the proxy is simply to conserve memory. But it's easy to see why some people are getting confused. Well according to some people it actually was or is working like that for them so apparently it's not just confusion. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted June 5, 2010 Applink Developer Report Share Posted June 5, 2010 It really worked a while, but not anymore. Even if I re-install it. It dosen't work. But when it worked it was amazing! Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted June 5, 2010 Advanced Member Report Share Posted June 5, 2010 Well according to some people it actually was or is working like that for them so apparently it's not just confusion. according to some people there are aliens visiting our planet and there's a big monster in loch ness. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted June 5, 2010 Reputable Contributor Report Share Posted June 5, 2010 Andrew fixed the split tool as it was not working in version 3.3.02 for windows,linux(not sure about mac) and reuploaded the file. New version when installed is 3.3.02A The split tool now works like a charm too, no longer leaving a cap in the two separated voxel meshes. sweet... Maybe this was fixed not long ago but I had stop using the split tool. Linux version not updated to version 3.3.02A last time I checked... Quote Link to comment Share on other sites More sharing options...
Andrew Shpagin Posted June 5, 2010 Author Report Share Posted June 5, 2010 Linux build uploaded too. Just for info: proxy changes are not transferred to original volume, but I am working on this. But you may do it manually (approximately): - let you are in 8X proxy mode - do changes (additive, not subtractive) - clone proxy - IncRes + Smooth + IncRes 2 times (if you are in 4X proxy, do IncRes 1 time, if in 2X - don't do it second time) - restore volume - copy cloned volume with SHIFT over restored volume Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted June 5, 2010 Applink Developer Report Share Posted June 5, 2010 human brains are funny. If you want it something so badly, you brains make it real. Something like that must happened for me Where is that phone number for my doctor Quote Link to comment Share on other sites More sharing options...
Javis Posted June 5, 2010 Report Share Posted June 5, 2010 human brains are funny. If you want it something so badly, you brains make it real. Something like that must happened for me Where is that phone number for my doctor It wasn't just you!! It really was doing it. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted June 5, 2010 Applink Developer Report Share Posted June 5, 2010 Yes it was... Maybe we got special editions...maybe this was some sort of bug but oh boy it was fast. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted June 5, 2010 Report Share Posted June 5, 2010 Check the Twitter Thread, this is coming for us all soon. http://www.3d-coat.com/forum/index.php?showtopic=4372&st=140&gopid=43826entry43826 Quote Link to comment Share on other sites More sharing options...
Advanced Member renderdemon Posted June 6, 2010 Advanced Member Report Share Posted June 6, 2010 Hi,I know I have allready asked this several time months ago,but Andrew,can you do something about lagging? I have tried 3.3 ,and I find that every time I use the move brush in voxel mode,after every release of the mouse/pen at the end of a stroke,there is a freeze,a lag(some seconds!) Keep in mind that I'm not complaining about speed,when I use the move brush if the voxel is not huge the speed is acceptable when dragging,but after every stroke I have to wait 1/2 or 3 seconds to finish the action. There was a time(more or less 1 year and some months ago)that the problem wasn't here. In surface mode there isn't any lag,so for now it's the only workaround(but jumping between surface to voxel is really slow). Quote Link to comment Share on other sites More sharing options...
Advanced Member splodge Posted June 6, 2010 Advanced Member Report Share Posted June 6, 2010 Hi, I've noticed the slight freeze too. I can only assume it's a result of Andrew modifying the Move code in order to minimize the artifacts that would sometimes show up. Quote Link to comment Share on other sites More sharing options...
Advanced Member michalis Posted June 6, 2010 Advanced Member Report Share Posted June 6, 2010 The voxels to surface mode must be more complicated than we think. When in surface mode, is it possible to go for retopo now? I experienced some problems in the past. I also tried to move (modify) the cashed (proxy) model, it didn't work but I'm asking too much (multires) for the moment. Great work in last 3.3 as far as I tested it Andrew, thank you. Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted June 6, 2010 Report Share Posted June 6, 2010 The voxels to surface mode must be more complicated than we think. When in surface mode, is it possible to go for retopo now? I experienced some problems in the past. Yes i have noticed that you can use Surface mode in retopo now. I also tried to move (modify) the cashed (proxy) model, it didn't work but I'm asking too much (multires) for the moment. Great work in last 3.3 as far as I tested it Andrew, thank you. Read the posts above, multi-res is coming soon, Andrew has it at least partly working now. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted June 6, 2010 Reputable Contributor Report Share Posted June 6, 2010 I would think that you can also use a proxy layer as well to Retopologize on...and once you're done, switch to the uncached original, with all the details, to bake down your normal and displacement maps. This way you can cache everything in Voxels, while Retopologizing, and keep your resources as low as possible. Quote Link to comment Share on other sites More sharing options...
