Member adamdaly Posted August 15, 2010 Member Report Share Posted August 15, 2010 I'm building a cartoon f86 sabre and found that getting the wing shape to be difficult. as you can see in this image the wing is straight and not tapered like i'd like and the tail plane although tapered has a bit of a curve in it and not linear like i'd want. I think a ffd cage tool would do this really well and probably have lots of other uses too. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted August 15, 2010 Contributor Report Share Posted August 15, 2010 Before an expert chimes in, I would suggest using the Pose tool. Start drawing at the wing tip and you get a gradient the gives strong effect at the red end. Then reorient the gismo to reduce the wing's cross section in a taper. Good luck! Quote Link to comment Share on other sites More sharing options...
