Advanced Member ozukaru Posted September 15, 2010 Advanced Member Report Share Posted September 15, 2010 I added a new 1GB ram module, now I have 3GB, the maximum that windows xp 32bit accept, as said the OS recognizes it without problem, but when I start 3d-coat it shows that available memory is still only 2GB (just the same amount as it did before the memory upgrade), is this normal? do I need to add even more memory to please 3d-coat?) Quote Link to comment Share on other sites More sharing options...
Member RenderBlur Posted September 15, 2010 Member Report Share Posted September 15, 2010 32 bit Windows still only allocates max of 2 Gb per application instance. There is one method around this using the /3Gb switch in the boot.ini, here is Microsoft's article on it, or you can Google for more: http://www.microsoft.com/whdc/system/platform/server/pae/paemem.mspx -Jim Quote Link to comment Share on other sites More sharing options...
Advanced Member ozukaru Posted September 15, 2010 Author Advanced Member Report Share Posted September 15, 2010 32 bit Windows still only allocates max of 2 Gb per application instance. There is one method around this using the /3Gb switch in the boot.ini, here is Microsoft's article on it, or you can Google for more: http://www.microsoft.com/whdc/system/platform/server/pae/paemem.mspx -Jim Thanks, it worked, and in this link is where to get acces to boot.ini http://support.microsoft.com/kb/289022 Quote Link to comment Share on other sites More sharing options...
