haikalle
Blender Applink
375 posts in this topic
3D-Coat/Blender applink manual
Applink Version: 2.00
Updated: 18.10.2011
1. Get Blender (http://www.blender.o...ad/get-blender/)
2. Watch this short Video (http://vimeo.com/30723894) to see how to enable the applink in blender
and how to use it.
3. Have fun :)
Note for linux users. You need to set your exchange folder manually. When you press 'Transfer' button first time
in blender it gives you a option to set it up. You can find Exchange folder from your 3D-Coat folder.
Edited by webmaster
Update to Version 2.00
1 person likes this
Script updated. 2 Lessons are online. I will make better ones later.
Thanks. I will do some cleaning this week. Today when I was looking the Applink in blender, it reminded me NASA spaceship panel. A lot of diffrent settings and buttons.
Didn't like it at all. Applink should be easy and fast to use. I would like to know your feedback about this. Do you like if there is all these small settings or should the
workflow be easier.
workflow be easier.
Thnx for your hard work haikalle.
I will try and test this week and give you some feedback.
I'm not going to try and tell you how to organize your tutes but I think it would be helpful to users if you you titled
the second lesson. Maybe like this: 3D-Coat Applink/Blender Lesson 2 :D
Thnx again,
P. Monk
On this computer it doesn't work still (E drive is default) but i am starting to think that is actually due to 3DC maybe.
I know this was the cause of it not showing in blender but you fixed that and it shows fine in blender always now. In 3DC i never see the app link menu though, i am just guessing here but even though 3DC is installed and working fine i am thinking it might use C drive as the default place to look for the app link exchange folder?
Very interesting. I will double check the code and if everything should work fine I will ask Andrew about it. Thanks for testing. Here is small update.
Now it will automaticly uncheck relative path and set graphics mode = 'GLSL', so my video tutorial 1 is almost useless. :)
coat.rar
I was able to briefly mess around with the blender applink so far and it's pretty nice with the new features!
Thanks haikalle!
Haikalle i was wrong before, it is working now :)
Sorry i had not watched the new video fully, i didn't watch it at first because i had seen the previous videos you made and thought it was the same as those. Basically the main thing needed was to set the extra things in blender like relative paths, GLSL and setting to textured view etc but it works now.
Thank you Haikalle,
You da'man. This is so awesome. :clapping:
What an awesome workflow. I'm now able to go from Blender to 3D-Coat to Photoshop back to 3D-Coat and back to Blender
so easily with everything loaded in Blender ready for a test render. It's just crazy fast. What a fool I am for not trying this sooner. :blink: You and Andrew are the greatest! :yahoo:
P. Monk
Thanks a lot. Glad you like it. I have big plans to improve the script so I hope I can take this into right direction.
My plan is to make seamless workflow even if your objects in your scene are in diffrent 3b files. Stay tuned :)
Right now one of the limitation is that everytime when you bring several objects into 3d-coat it will merge them into same
.obj file. I hope that when Andrew has some time he could think the workflow for situation where you bring several objects into
3d-coat paint room( not the same time) and taking them back into your 3d program.
One thing i noticed last time i used this was if i scaled down the model in blender then export to 3dc and if i re-imported from 3dc after and back to blender it had 2 models at different sizes.
Is the Modifiers option needed for this or is that different? when i think think of modifiers i think the blender effects but scale and rotations etc is a standard thing so different?
Yes, modifiers are diffrent thing. They should not have any effect on behaviour you had. When you pressed export button did you have "export obj" on? Or did you use .obj file already there. And when you pressed import button was "Mesh" on or off?
Also when you see that something odd happens it help if you check your blender command prompt window. It usually say the root of the error? If there is an error, taking a screenshot would help a lot.
hmmm, can't get mine to work, still don't know my way around 2.5
is it possible u could post a blender where it's preinstalled? hehehehe :pardon:
@haikalle -
That happened just with the default settings that are there as soon as you add it to blender, all i did was set the path to the object and exchange folder. The scale change was done in blender with it's shortcut (s key i think), I think i looked in the command prompt window also and it seemed fine so i just guessed you had to keep the model at the same scale but i guess not.
By the way with the model does it matter where you load it from to start with? By this i mean is it better to load it in blender or 3DC first or should either be ok?
Script updated 1.61
coat.rar
- Supports 3d-coat -> Blender workflow
- New video tutorials
@Digital777
You can try this script version. With this it dosen't matter where you start. You can start your model in 3d-coat or blender.
@kay_Eva
I posted a new tutorial. There is no talk but they show the basic workflow. Hope it will solve the issues you have. But if dosen't, let me know.
Thanks haikalle, i just downloaded and will test the new version, the new videos that show the workflow are useful also. :)
Yes. It supports both, 32 and 64 bit systems.
For some reason I can't find the same path you use when I try to extract from winrar. This is the only path I get (C:\Program Files\Blender Foundation\Blender\2.54\python\lib)
Hi Denis!
Can you send the link where you downloaded it that I can test the same blender version you have. Did you use the installing program
when you installed blender? or did you use winrar program?
yes, I downloaded it here
I used the 64 bit with the installer.
Denis. By default when using installer, blender puts those folders in diffrent place. You should find them here.
c:\Users\username\AppData\Roaming\Blender Foundation\Blender\2.54\scripts\io\
If you want to change this, When the installer asks "Please specify where you wish to install Blender's user data files"
select the second option. Then you should have them like in video tutorial. Hope this helps.
