Member Bisse Posted October 8, 2010 Member Report Share Posted October 8, 2010 When using reference images in the X, Y or Z axis, there is this "edit images placement" which brings up a window where you can control stuff like opacity etc. The problem I'm having atm is that I can't get this window to show when I click on it from the drop down menu. Have you guys experienced something similar, and do you know how to bring it back somehow? - I have tried to reset the UI but that didn't do it. Quote Link to comment Share on other sites More sharing options...
Psmith Posted October 8, 2010 Report Share Posted October 8, 2010 Bisse: To get the "adjustment" rectangle to return select "Camera/Background/Edit image placement". At least this works for me, on my system. It works again, even if you select "Close" from that open window. Try this again, and if it still doesn't work, let me know. Greg Smith Quote Link to comment Share on other sites More sharing options...
Member Bisse Posted October 9, 2010 Author Member Report Share Posted October 9, 2010 Thx for the reply - I think that this is precisely what I do and have done several times with success, but now I seems to have stopped working. When I hit the button, the transform gizmo's will appear but not the control window... ] Quote Link to comment Share on other sites More sharing options...
Psmith Posted October 9, 2010 Report Share Posted October 9, 2010 Bisse: Try "Windows/Restore all pages to default". I'm not sure if this will solve it or not. Which version are you using? If it is not the most recent beta version, (many bug fixes), then install this and try again. Greg Smith Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted October 9, 2010 Report Share Posted October 9, 2010 I've had this happen before and it does appear to be a bug. Restarting 3DC solved it the one or two times that it happened. Quote Link to comment Share on other sites More sharing options...
Member Bisse Posted October 10, 2010 Author Member Report Share Posted October 10, 2010 Thanks for the replies. I'm on version 3.5A The "Windows/Restore all pages to default" worked and I got the edit images placement window back. Niceness! :-) I wasn't aware that one could download beta's - thanks for that tip. Currently downloading 3.5.02. Quote Link to comment Share on other sites More sharing options...
