3D Coat Forums
Garagarape
Garagarape sketchbook
This is a beautiful machine! Of course its sculpting. By all means. :clapping:
To use primitives, booleans, subtractions, cuts, this is more sculpting than using some brushes-tools.
If you need rocks for scenery I can help.
Thank you all!
I'll try to make nice textures for this one,
with rust and scratches on the paint.
But for now, it's retopo time.
Thank you for watching.
Geothefaust, thanks!
I guess there is more important things;
some may like the "What colour will come out this time?" surprise.
By the way, thank you for all the tutorial videos. It helps a lot.
Sorry for the slow reply!! (My pleasure on vids, glad you found them useful)
Been watching your stuff here, lots of great work, very cool. :) I'm glad you post so much of your work. Keep it coming.
Really enjoying the hardsurface mechanism you have there.
Geothefaust,
Thank you for your message!
I'm kind of addicted to 3dCoat :)
Hard surface and mecha is a great challenge with this app.
Don't wan't to lose against ZB users.
Almost there for the "body" part.
Arms, Headlight and water-booster left.
There's a big normal problem on the symmetrical middle line.
May be because I baked half?
Soon, I'll have to say "this is gallery stuff". With a better surrounding scene and some rusty painting probably. :clapping:
Meanwhile I see half of model having reversed normals. I think the correct is the left part. Looking at your retopo, I really don't understand whats happening with symmetry.
You did the same mistake as in the goblin figure. You should use as separated layers as possible for this one.
My trick is this? Just imported tinkels meshes in blender and constructed low poly versions. These I use just for painting, no need to bake. I could use them as retopo meshes if it could be possible to paint in vox room. As all fine details are possible in paint room, I really don't understand why to retopo. Except of boolean operations of course. But always separated meshes as possible.
You wont loose against zb users. Most of what you see there are coming from other apps, its ridiculous what they try to achieve with zb as modeler. Blender, modo and all the main stream apps are better for the job. Even sketchUp if you know how.
What I don't understand in zbrush forum is how they paint textures on meshes with no friendly to zb topology. Zb can't directly paint on UV maps, you can't even paint on stretched topology. As in MV mode. I mostly use 'groboto' as helper for zbrush. But this is another story.
Thanks Michalis!
Ouch! I don't have Blender on my pc yet.
This time I did use different layers for retopo (Digman's method I think),
in #165 pic all layers are shown at once but it is separated layers workflow.
Yes, normals are reversed. Probably a problem with Marmoset viewer.
I'm gonna check this soon.
Did you see this bike modeling video?:
http://www.zbrushcentral.com/showthread.php?t=95181&page=6&pp=15
I don't find it ridiculous. Clip Brush, matchmaker, masks and stuff like that
seem to be rather cool tools to me. But I also found ZB strange for it is not
that much user friendly (Could get lost in menus for hours)...
I like 3dc because you can use it in a more intuitive way.
Arrhhh! Tried to Triangulate the mesh before baking,
moving Uvs +1 to avoid overlap, checked the obj normals
and just found nothing wrong... Still the normals are flipped.
I probably have to ask Marmoset Toolbag developers to give advices.
Did you mirror the half mesh after having done the uv ?
1-Unwrap(done)
2-turn symmetry on
3-Click Apply symmetry
4-turn symmetry off
5-Bake (merge to ppp)
--tell me how it went.
Very nice work btw :)
Oh! BeatKitano, Artman,
Thanks for the advices.
I didn't mirrored the uvs. I meant I had overlapped uvs at first.
Then I tried to slide them +1 in the Maya uvs editor in order to have no uvs overlay and took the .obj back to 3dc.
But the problem is not there. There should be no problem baking normal map with uv overlap here.
It is more an engine matter?
I'm going to have a try with Artman's method and will tell you if there's a progress.
BeatKitano > That was funny to see your avatar in Polycount Marmoset thread.
I'm always late at checking for good sites and app. Still that was fun to read about this viewer history
and see all artists trial and error.
Oh no! That didn't work.
Building half the model and having it -z copied in Maya
or applying symmetry in 3dc (with very thin parts
I often get them merged in a strange way) gives the same result.
Probably something to tweak to have the model correctly displayed
in Toolbag. I give up for today. Time to bake....meal.
Thank you for helping. I'm very thankful for that.
If I find a way, I will post the solution here.
See you soon.
Beatkitano,
You gave me the right hint. I baked the normal map
in Xnormal and realized that it was quite different;
it is rather sharp, but over all, the Y value is the
opposite of the one baked in 3dc.
I just inverted the green channel of the normal map
and that was ok.
How stupid I am! It is an old trick written in many forums.
Different engines = Different normal map RGB channel values...
Anyway, thank a lot for your help!
Cyber Froggy :) I love the detail on this very cool. I love how you can really push out bizarre shapes and mechanism with minimal topology when baking voxels. :clapping:
One of the most convicing hard surface models around!
And an "honest" post as we can see the final result after topology (excellent) and baking. Not just a vox concept or a 10M zbrush render.
:clapping: :clapping: :clapping:
I noticed a quadrangulation of some casted shadows. I'm wondering if this has to do with normal maps or its just right. Nothing to do with the quality of this image.
Thanks! This is not final.
The diffuse and specular are not done yet.
I just posted to change my mind, this is WIP.
BeatKitano > What is CA? Ambiant color?
I'm not satisfied with the actual color scheme and post effects.
Yes, there is probably a need for tweaking specular.
Michalis > I can't see the shadow problem. If you have time would you mind
showing me wich area it is locatde on.
Marmoset viewer casts nice shadows. But, shadows can go funky (bias problem?)
sometimes when cone angle is too wide I guess. Didn't noticed a problem this time though.
I'm not a lighting specialist. Thought it would be nice to make an effort this time.
Oh, I see. Yes that's may be too much.
Just wanted to try to express the "blured" water in deep sea.
It's not probably the best way to do it. Thank you for the advice.
