artman
Export Dense quad makes 3Dcoat crash.
8 posts in this topic
3.5.09 Cuda Dx or gl
http://www.mediafire.com/?cse6ablpg5vba9v
This file Crash 100% of times.Usually saving before exporting prevent crashes but not this time.
I need to export this as quads, its not possible to use auto-retopology+Merge to PTEX/MV ,some pieces are too thin(clothes).
Also scale is still not preserved from original position/scale ,even if I choose "yes" to the "remember scale question" when merging objects to voxels.
I need to reposition each objects manually after export and its a pain.
Thanx for looking into that.
(Taros,sorry for not using Mantis,Im in a little hurry right now...)
I have run into the crashing issue also.
On your file, if I hide Volume1929 and Volume773_copy, everything exports to dense quads fine.
Thanx,it is true.Maybe it will give Andrew better idea about cause.
Crash...crash... crash
Still you can export a tri mesh with the right scaling. So what's wrong here?
I need quads for this project.
Problem fixed in any version later than 3.5.10A.
Thanx.
You are really in a bug-squashing frenzy. :)
Thanx.
3.5.10B is on server even if not announced. You may take it if need.
