Tser
"Use spacing" not working properly
3 posts in this topic
Using the Build tool, if you enable "Use spacing" on the brush and choose a default alpha, the spacing won't work unless you increase the radius of the brush to 70 or larger, anything under 70 is like having "Use spacing" switched off.
Having done some more testing I have found that it again works with a brush smaller than 10, anything over 10 and under 70 causes the "Us spacing" to be turned off.
T.
"Use Spacing" is definitely not consistent for all tools. Try some of the other similar tools and alphas to get the effect you are trying to achieve.
Greg Smith
I fixed the issue, but you may avoid problems even now if you will turn off CUDA in Voxels menu before need using spacing in Build.
