Member a3dcreator Posted April 12, 2011 Member Report Share Posted April 12, 2011 Just bought my version of 3d coat. im trying to look for the sfFill tool. but none of the surface tools show up in my 3d coat. all i have under surface is this. surface ________ draw pinch shift flatten clay rapid no surface tools?? like sfFill, gum , surface extrude??? thanks guys. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted April 12, 2011 Applink Developer Report Share Posted April 12, 2011 Hi! In voxtree, press that small cube icon. After you have pressed it, the icon changes and also tools. Now you are in surface mode. Press that small icon again and you are back to voxel mdoe. Hope this helps you. I'm excited to see you first sculpt. Bring it on Quote Link to comment Share on other sites More sharing options...
Member a3dcreator Posted April 12, 2011 Author Member Report Share Posted April 12, 2011 Hi! In voxtree, press that small cube icon. After you have pressed it, the icon changes and also tools. Now you are in surface mode. Press that small icon again and you are back to voxel mdoe. Hope this helps you. I'm excited to see you first sculpt. Bring it on thanks for your reply. i actually have tried that already. i tried following the directions in the manual very closeley. but the tools still do not show up. but i did find something that does exactly what i want it to do. which is fill clay voids. if you right click on the voxel tree the option is in there. it still boggles my mind though that the surface tools like i mentioned above do not show up. Quote Link to comment Share on other sites More sharing options...
Applink Developer haikalle Posted April 12, 2011 Applink Developer Report Share Posted April 12, 2011 That's odd. When you press that small icon do you see anything to be changed in tool panel? Do the voxel tools stay? Quote Link to comment Share on other sites More sharing options...
philnolan3d Posted April 15, 2011 Report Share Posted April 15, 2011 Also make sure you have the vox tree layer selected when you click the cube icon, not a different layer. Quote Link to comment Share on other sites More sharing options...
Member Colwax Posted April 15, 2011 Member Report Share Posted April 15, 2011 Hi a3dcreator, Just bought my version of 3d coat. im trying to look for the sfFill tool. but none of the surface tools show up in my 3d coat. all i have under surface is this. surface ________ draw pinch shift flatten clay rapid no surface tools?? like sfFill, gum , surface extrude??? thanks guys. Just wondering which version of 3D-Coat you're using? Are you using the latest Beta version?? regards Colin Quote Link to comment Share on other sites More sharing options...
