This might be what you're needing to know?? You can hit the numpad keys to switch between side, top, etc views.. You can hold Shift when rotating the view to "snap" to certain axiis. If you are in perspective mode you may notice that your model doesn't appear centered.. so you may want to switch to orthographic view, that can be toggled by hitting 5 on the numpad. You can also click up on 'Camera' in the upper right corner of the viewport to access those views, and also the little icons to th
Posted by XRA,
0 reactions
Go to this post
