Member pugmugger Posted July 15, 2011 Member Report Share Posted July 15, 2011 Hey Guys, When using 3Dcoat, we've noticed the program slows down a lot the longer it stays open. Saving and opening 3Dcoat again fixes the slowdown. So I'm thinking it could be to do with paint strokes the artist makes being stored in memory and not being cleared after a certain number of steps. I was wondering if anybody has any tips for performance tweaks in 3D coat. I cant seem to find any memory management options like changing the swap file path and size, amount of undo steps etc. We're running intel core i7's with 12 gigs of ram and geforce cards that have over a gig of Vram. Lastly, would having a Quadro card of similar Vram spec make a big difference in performance? thanks, Chris. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted July 15, 2011 Reputable Contributor Report Share Posted July 15, 2011 Hey Guys, When using 3Dcoat, we've noticed the program slows down a lot the longer it stays open. Saving and opening 3Dcoat again fixes the slowdown. So I'm thinking it could be to do with paint strokes the artist makes being stored in memory and not being cleared after a certain number of steps. I was wondering if anybody has any tips for performance tweaks in 3D coat. I cant seem to find any memory management options like changing the swap file path and size, amount of undo steps etc. We're running intel core i7's with 12 gigs of ram and geforce cards that have over a gig of Vram. Lastly, would having a Quadro card of similar Vram spec make a big difference in performance? thanks, Chris. There was a problem with this several builds ago, but Andrew did a lot of work tracking down memory leaks and such. What build are you using? The latest is 3.5.21A Quote Link to comment Share on other sites More sharing options...
Member pugmugger Posted July 19, 2011 Author Member Report Share Posted July 19, 2011 Thanks for the response Abnranger. We're on 3.5.19A , I'll update us to the latest. Good to know this issue has been reported/worked on. Maybe 3.5.19 still had the memory leak issue present. Would still be nice to have some performance options exposed like undo steps, page file etc. Quote Link to comment Share on other sites More sharing options...
Member kbrilliant Posted August 10, 2011 Member Report Share Posted August 10, 2011 I'm experiencing a memory leak on v 3.5.23C Cuda 64 bit Windows Vista while per pixel painting. I'm not sure how to recreate other than working on the scene. I can send it in if needed. Ken Quote Link to comment Share on other sites More sharing options...
Member Bisse Posted August 19, 2011 Member Report Share Posted August 19, 2011 I'm experiencing a memory leak on v 3.5.23C Cuda 64 bit Windows Vista while per pixel painting. I'm not sure how to recreate other than working on the scene. I can send it in if needed. Ken I am also experiencing a memory leak in voxel mode. The program quickly eats up 10 gb of ram. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted August 19, 2011 Reputable Contributor Report Share Posted August 19, 2011 I am also experiencing a memory leak in voxel mode. The program quickly eats up 10 gb of ram. Large consumption of RAM in Voxels doesn't really indicate a leak. What does is when you initially load the scene, and without doing anything to add to the RAM usage (like add a new object/layer or increase res on a layer) you observe consumption climb significantly. Or after deleting portions of the scene that should drop RAM consumption, it doesn't (dump the data from RAM). This has been the case in the past, but I haven't noticed it too much lately. Quote Link to comment Share on other sites More sharing options...
