3D-Coat 3.7 updates thread
1,787 posts in this topic
Thanks BeatKitano,
I dealt with the UAC around ten seconds after installing Windows 7 for the first time it is no longer a problem :)
Compatibility tried that makes no difference.
I have been running the latest nVidia drivers (295.73) since thier release 21/02/2012
The only thing I can think of is that the delay is caused by a serial number check?
I seem to remember that there was a file we could delete to help solve problems ..trouble is I cant remember
what it was ... anyone remember?
Thanks
Was it "Options.xml" in the "Documents/3D-CoatV3" folder?
I dont know , I deleted it but I did'nt notice any difference.
Thanks
Updated to 3.7.07 (win)
- Voxel LC tools may be duplicated by RMB click. You may customize new tool in own way and share new brush. In so way you may create for example variation of GeneralBrush and store/share it.
- much faster initial loading
- Sketch tool got improvement. Now it is possible to assign images as top and bottom stencils and set tapering angle (positive and negative). Examples - http://bit.ly/xv0491 http://bit.ly/yTHhh9 . It works as advanced loft tool that may join contours of different topology.
- fixed several UI glitches.
- fixed problem http://3d-coat.com/mantis/view.php?id=486#c1396
Ah.. much much faster startup :)
Thank you
Also removeclay does indeed removeclay:
I also got a crash (but no report form !) after trying to delete a liveclay brush I just duplicated.
I found and fixed crash. But I can't reproduce smoothing problem.
Removelay is still not ready, I forgot to exclude it. It is intended for global removal of details, will work like hypersmoorh to get clean smoothed surface even if there was many details and even holes.
whats diferent from last build?
during PPP import the program stop work
The difference is that regular builds are compiled against older SDK 10.5, because there were some requests to include Mac OS X 10.5 Leopard support. When you click File/Import/Model for per pixel painting do you see file selection dialog? Does 3D-Coat stop responding after selecting model file and closing file dialog?
I docked my UV preview window on the left and noticed while clicking on UV islands that my clicks were going through the window and onto the mesh behind it. This results in marking seams you don't want marked, often without realizing it's happened. Doesn't seem to be an issue with Add clusters and Edge loops modes, just Mark seams.
Also is there a way to keep 3D Coat from destroying my smoothing groups? I bought a mesh over in OBJ format so I could do the UV's and discovered after finishing and exporting back to the originating app that my smoothing groups were gone. I asked about this in the new user area but never got an answer. They were time consuming to set up in the first place, and took just as long to redo them. On top of that I may need to send my mesh back to 3D Coat for more UV work. If there is something I'm missing or some trick to it, please let me know.
@Sergy
using last build(6b)in lion:it allows to chose mesh in window and then stops (now it flickers)so no new window for import settings.
note:it allows PPP import through the launch window.
your build 10.6 dont work at all in snow or lion
-it shows a crazy frozen window with items from 3dcoat interface and or desktop or whatever.does it work for you?how can it be?
cheers
What should happen is that a second list should show next to the first, when the first list reaches the boundary of the Viewport.
Or a means to have a persistent dialogue. Like a modifier key click. With possibly a higher power of management tools and buttons avaiable. Like an "advanced" one.
I agree. Very annoying problem. Same thing happens when you click the Retopo menu...the dropdown list is so long that when you choose an option that is over an object or UV island, it will select through the menu.
Can't reproduce any of that problems even if tried a lot. Maybe short video will help a lot.
If you exporting from some 3D package you should export OBJ file with normal. 3DC uses normals to detect smoothing groups.
using last build(6b)in lion:it allows to chose mesh in window and then stops (now it flickers) so no new window for import settings
The dialog "Import object for per pixel painting" has an edit box "UV-set name". Please try to click on screen to find that edit box. It seems like the dialog exists, but is invisible.
Ok
Please copy the executable to the folder with 3D-Coat data files.
Updated to 3.7.07A (Win)
- fixed crash when you delete custom tool
- fixed possible surface smoothing issue
- fixed bug in VoxLayer tool - not always possible to select area
Mac & Linux builds expected very soon.
hi
do you mean i drag it into 3dcoat aplication folder?sounds good!and what about the original 3dcoat that was there?do i keep it there or do i move it out?i tried it now into 6B build and when i open 10.6 its named 6B!please advise,im getting closer!
thanks
any way no luck with lion,with 10.6 build inside aplication folder,for importing PPP.no window settings,clicking on screen!
please confirm its OK two builds on same aplication folder.
thanks for your help
(i would drop leopard support and concentrate on more recent OSX as it pays in the long term .i think!)
@Andrew
thanks,dowloading now!
best stuff as always
have good time please
This morning I tried to duplicate a function with rmb.
The application crashed right away and then I download latest vesion ( 7A ).
The interface has disappeared, only a grey screen is all that's left of 3D Coat. :excl:
Installed 6C again, it worked.
Feedback report concerning non editable retopo mesh after an autopo in 3DC Beta V3.7.06B version for the Mac.
The issue should be fixed in the latest build 3D-Coat 3-7-07A. Thanks a lot for the detailed report and the comparison between versions!
It’s ok as long as the executable names are different (and they are).
I’ll install Lion. Let’s hope that the issue will manifest itself.
SERGYI , many thanks indeed - look forward to downloading.
Update: Yes indeed SERGYI - it is fixed :-) Thank you.
Andrew and SERGYI,
It appears that there is an accuracy issue with painting with the pose tool across symmetry in v3.7 versions. After such an operation Menu bar>voxels >Symm Copy will highlight the inaccuracy as shown in this demo.
The Freeze tool mask has no such inaccuracy but there does seem to be an issue when switching from Freeze to Pose mode. The selection must be inverted first then inverted back before the pose tool functions correctly in this scenario.
http://vimeo.com/38434511
Mac: 10.5.8
Temporary upload whilst in investigation of this issue.
I can't get it to happen with 3.7.07 and I've tried everything I could think of. It happened often with 3.7.06 though. So either it requires a specific set of circumstances in order to happen, or recent code changes to the UI have fixed it somehow. I can still select islands in the UV preview window by clicking through overlapping drop down menus though, which is the issue AbnRanger posted.
That is exactly what I've been doing.
3ds export settings:
post-9206-0-88913300-1331705419_thumb.jp
3dc import settings:
post-9206-0-65025200-1331705442_thumb.jp
3ds import settings:
post-9206-0-49672900-1331705464_thumb.jp
When I choose the "Export UV" option (as OBJ) in 3D Coat (which has no export options related to this), it takes all of my polygons and adds them to smoothing group #1 while deleting #2, #3, and #4. I know for a fact 3D Coat is seeing all four of my smoothing groups on import because if I turn the "Smooth object" toggle on and keep the "Ignore smoothing groups" and "Auto smoothing groups" import options off, my mesh looks exactly how it does in Max with it's turbosmooth modifier (which is set to separate by smoothing groups, something I use very often). As an aside, an OBJ imported into 3D Coat with those particular settings ends up with slightly altered geometry due to the smoothing it's applying. These alterations then get exported by 3D Coat which is another reason why I've been importing my OBJ's with all of 3DC's smoothing options turned off, the original reason being an attempt to stop 3D Coat from destroying my smoothing groups.
Another interesting quirk I just discovered in the UV room is when using a custom texture. If I alter the texture in the paint room and resave it, 3D Coat won't reload the file for display when chosen. The workaround is to change the file name of the texture upon each save and then load that new image file into the UV room checker. Kind of annoying but not really a big deal. I only discovered this because I was trying to fix some distortion.
Have been away for a while for work & haven't had any time to spare :( . Just been using the latest build &
REALLY noticing a fantastic improvement in performance when merging voxel layers. :D Awesome work everybody. :D
Just been using the latest 07 mac beta and is it just me but the UV's seem terrible on export... the low poly UV's don't seem to match up at all on export and the mid polys do match up but the normal map creates horrible seems.
Not sure if this is a bug but I hadn't noticed such behaviour before and makes exporting paint on a low poly for animation really difficult, not sure if you can export properly at the moment?
@cl-apps
And 3dcoat developers
Indeed there's a major bug here.
Latest build is another useless beta.
3.7.01b was the last usable build for mac users.
You're doing something very very wrong. You probably know better than me.
Please!!! Give us a decent build. Test it first.
Because I'm convinced that you didn't test it before uploading!!!
Exactly so, this is my opinion, Andrew. Or, try to explain it better.
Here a fast test, autopo, manually unwrapped. Looks OK in 3dcoat but see the import in blender. Tried obj and lwo format.
I even tried modo, zbrush, same results. The exporter of 3dc is broken. You didn't test it, did you?
post-2454-0-20973100-1331920288_thumb.jp
