Snow, Tire and Car Shaders WIP
3DArtist
I've been working on some multitexture/multilayer shaders the last few days and want to share the progress so far. I hope to clean up the code, add some final touches and release a small shader pack (currently DX only).
These shaders are a combination of PicMat, textured, and reflection shaders rolled into one with some fresnel thrown in.
  • 1 month later...
I love it - love ur works and the shaders are wonderful, can one help me, how can I add shaders? And what u need to do own shaders?
Thanks Monkeybrain!
I uploaded the shaders to the Exchange Library on the forum here.
After you download the 3dcpack file:
You'll need to take the ".zip" off the file to be able to install it through 3D-Coat.
To install, go to File -> Install Extension -> then select the .3dcpack file.
One way to create your own:
1. Right-click on a shader in the Shaders palette (i.e. PicMat_Clay_Depth)
2. Click "Construct new shader" and enter a name for the new shader.
3. Click on the texture button to load a new picmat.
A picmat is just a shaded sphere that you can render from a 3D program (i.e. blender, Lightwave, Modo)
ZBrush has some examples here. You can't use them for 3D-Coat but they should give you an idea to create your own.
