Member JPWestmas Posted February 17, 2012 Member Report Share Posted February 17, 2012 Hi all, I was wondering if anyone had some tips for making the falloff of the clone stamp brush much more soft like the rubberstamp tool in Photoshop. I love to use this on a model directly but it seems no matter what I do, the edge of the brush is always pretty hard. Maybe there are some settings I'm not aware of? Quote Link to comment Share on other sites More sharing options...
Advanced Member johnnycore Posted February 17, 2012 Advanced Member Report Share Posted February 17, 2012 When you use the clone stamp in 3DCoat you can use a brush with a soft edge, should be softer than the one with the harder edge. Quote Link to comment Share on other sites More sharing options...
Member JPWestmas Posted February 17, 2012 Author Member Report Share Posted February 17, 2012 When you use the clone stamp in 3DCoat you can use a brush with a soft edge, should be softer than the one with the harder edge. Yeah it is a little softer, just doesn't seems to get as soft as the regular brush for some reason. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted February 17, 2012 Reputable Contributor Report Share Posted February 17, 2012 Adjust the falloff parameter at the top of the UI Quote Link to comment Share on other sites More sharing options...
Member JPWestmas Posted February 17, 2012 Author Member Report Share Posted February 17, 2012 Yeah it is a little softer, just doesn't seems to get as soft as the regular brush for some reason. Ook so, same brush. As you can see in the pict the clone stamp (white circle on the right) is more harsh around the edges. the falloff is at 100% Quote Link to comment Share on other sites More sharing options...
Member JPWestmas Posted February 17, 2012 Author Member Report Share Posted February 17, 2012 hmm I wonder if the model's scale has anything to do with this. Quote Link to comment Share on other sites More sharing options...
Advanced Member herve_bis Posted February 18, 2012 Advanced Member Report Share Posted February 18, 2012 it happen to me also..no matter what I always get a sharper edge than the normal brush... even with faloff at 100% Quote Link to comment Share on other sites More sharing options...
Advanced Member Zeddicus Posted February 18, 2012 Advanced Member Report Share Posted February 18, 2012 Edit > Preferences > Show 'Focal shift' in top panel I think it's off by default. I'm still a 3DC noob but maybe that might help you. Values can be set from -100% to +100% (-90% works good). While playing around I found the fourth brush (counting horizontally from left to right) seems to produce the softest edge. I'm sure you already know, but I'll say it anyways; you can always make your own brushes. Don't forget you can smooth by holding the shift key as well. There is also varying stroke types in the upper left of the menu and a setting for borer width that might also help depending on which stroke your using (try the rectangle at zero and then 100 to see the difference). Quote Link to comment Share on other sites More sharing options...
New Member JBrownSyandus Posted September 21, 2016 New Member Report Share Posted September 21, 2016 This is a really old topic, but I was also having this issue. Anyone have a solution? Quote Link to comment Share on other sites More sharing options...
Member kwhali Posted December 17, 2017 Member Report Share Posted December 17, 2017 This still appears to be an issue almost 6 years later. I am not noticing any effect of different alpha/depth/falloff or focal shift with Copy Clay with various combinations of tool options. Beyond depth values pushing the applied clay data to the mesh at higher elevation, only blend with laplacian and adjusting the strength seems to really have effect, doesn't necessarily allow for properly blending with a fall off / smooth / softened edge if the cloned data has varied elevation.. Quote Link to comment Share on other sites More sharing options...
Carlosan Posted December 17, 2017 Report Share Posted December 17, 2017 Bug reported Thx. 1 Quote Link to comment Share on other sites More sharing options...
