TLE
toggle free in voxel or surface mode
4 posts in this topic
can i set up a hot key so i can hold down while i am in sculpting mode and draw a mask to free that area i don't want to have effect then after release that hot key, it will bring me back to the original tool i was in so i can countinue sculpt w/o having click on free tool to draw then have to click on the last tool i was in?
like in zbrush hold down ctl and draw a mask in a fly?
Thanks
T
Well there is a freeze tool in voxel surface mode, Im quite sure you're able to set a shortcut to it.
You should hover over the tool and it will give you hints what you can do with it and how to change the shortcut.
Hi there,
There is no function for sticky keys at the moment, but you can certainly set custom hotkeys for just about any tool in 3DC, you can even have multiple tools for the same hotkey to toggle between them.
Absolutely. I've pressed Andrew to add it before (leading to at least hotkey stacking), this is something I'd like to see expanded upon.
