3D Coat Forums
Rhino
More in cavity (Per pixel)
I can't seem to get anything out of the 'more in cavity' option in Per pixel mode, no matter what the scale setting. Is there a trick to it or should I just stick to Microvertex mode?
:blink:
can i ask how do you get a cavity map ?
ty
:blink:
ty
How do you mean, exactly? My workflow involves baking high poly model details to a low poly. I use Xnormal to bake all the maps I need, including the normal map which you can use to generate a cavity map using the tools within Xnormal.
Oh i see... ^_^
Can i ask for your detailed workflow and settings ?
ty ! :)
Sure. I'm creating hard surface game assets mostly, so I....
1. Create high poly mesh in Blender or 3DS Max.
2. Import into 3DCoat (Per Pixel mode normally or Microvertex if I want to distort mesh), Auto-seam and apply UV in UV mode.
3. Paint model in Paint room (3DCoat)
4. Retopologise in retopo room (3DCoat), Auto-seam UV and export low poly mesh.
5. Export high poly model and diffuse / spec textures from paint room.
6. Import low and high poly mesh into 3DS Max or Blender and create cage for baking. Export both cage and low poly model again (to make sure vertex numbers match).
7. Bake textures in Xnormal (diffuse, ambient occlusion, normal, spec). Create cavity map from normal map in Xnormal and combine maps in Photoshop (multiply AO map onto diffuse and color burn cavity onto that).
I should get into creating/adding hard surface stuff in 3DCoat, but I haven't had time to learn properly yet.
