Member existe Posted April 30, 2016 Member Report Share Posted April 30, 2016 I am sure I am missing something obvious but in Vox (or does this require surface?) how does one cut off at an angle? Trying to find similar functionality to clip curve from ZB but with Voxels. Cut Off has limited "E Panel" choices and anything angle related seems inaccurate. Again I am sure I am missing something obvious. Thank you. Quote Link to comment Share on other sites More sharing options...
Advanced Member Solution Ballistic_Tension Posted April 30, 2016 Advanced Member Solution Report Share Posted April 30, 2016 up in the E Panel choose the vertex lasso . Then click once to start HOLD SHIFT an that will snap to 90,45 as you move it about.. you could also turn on the 2d grid and snap to 2d grid options under VIEW. You will probably want Orthographic Projection to be on for a straight cut off. Quote Link to comment Share on other sites More sharing options...
Member existe Posted April 30, 2016 Author Member Report Share Posted April 30, 2016 (edited) Thank you Edited April 30, 2016 by existe Quote Link to comment Share on other sites More sharing options...
