Member Fabio Dona Posted August 2, 2009 Member Report Share Posted August 2, 2009 Hi, my name is Fabio Dona. I'm a 3d artist from Brazil. I decided to create this thread to document my progress with 3d-coat. I started using it 4 days ago, and I'm amazed by the possibilities of voxel sculpting This is my first sculpt. It's not finished or anything. I don't know if I'll keep working on it but I'll try to post everything I make with 3d coat here. I hope you like it. Quote Link to comment Share on other sites More sharing options...
Taros Posted August 3, 2009 Report Share Posted August 3, 2009 Really nice skulpture. A good start. Quote Link to comment Share on other sites More sharing options...
Advanced Member rimasson Posted August 3, 2009 Advanced Member Report Share Posted August 3, 2009 WOW Quote Link to comment Share on other sites More sharing options...
Advanced Member cuffins Posted August 3, 2009 Advanced Member Report Share Posted August 3, 2009 did you sculpt this in 3d-coat or import from an other app? Quote Link to comment Share on other sites More sharing options...
Member Fabio Dona Posted August 3, 2009 Author Member Report Share Posted August 3, 2009 did you sculpt this in 3d-coat or import from an other app? I'm still learning the program but this is all 3d-coat. I did this directly in pose. It's actually the first time I did a sculpt without symmetry from the beginning. Thank you for the comments, I'll try to post more soon. Quote Link to comment Share on other sites More sharing options...
Contributor Tony Nemo Posted August 3, 2009 Contributor Report Share Posted August 3, 2009 I'm still learning the program but this is all 3d-coat. I did this directly in pose. It's actually the first time I did a sculpt without symmetry from the beginning.Thank you for the comments, I'll try to post more soon. You have a good eye! One thing tho', the face looks eerily masculine, especially in the last pose. Quote Link to comment Share on other sites More sharing options...
Member Fabio Dona Posted August 4, 2009 Author Member Report Share Posted August 4, 2009 Thank you, Tony. Yes, I noticed that too. I'm not using reference for this, but I tried to work a little more on the face... This model is getting too hard to edit for me. I can't move stuff around at this stage in 3d-coat in a non destructive way, it's not as practical as in a poly sculpting app. Everything is too slow in my machine right now, So I think I will finish this in Zbrush. I'm still impressed with the voxel sculpting possibilities, but speed is crucial to make fine adjustments at high resolutions... I'm not happy with the brushes too, I guess I need more resolution, but then it's impossible to work without hiding everything.. and hiding parts of the model is way too slow for me, navigation is getting too slow. Anyway, I'll try to do more stuff with 3d-coat to post here. Quote Link to comment Share on other sites More sharing options...
Contributor LJB Posted August 4, 2009 Contributor Report Share Posted August 4, 2009 Thank you, Tony. Yes, I noticed that too. I'm not using reference for this, but I tried to work a little more on the face... This model is getting too hard to edit for me. I can't move stuff around at this stage in 3d-coat in a non destructive way, it's not as practical as in a poly sculpting app. Everything is too slow in my machine right now, So I think I will finish this in Zbrush. I'm still impressed with the voxel sculpting possibilities, but speed is crucial to make fine adjustments at high resolutions... I'm not happy with the brushes too, I guess I need more resolution, but then it's impossible to work without hiding everything.. and hiding parts of the model is way too slow for me, navigation is getting too slow. Anyway, I'll try to do more stuff with 3d-coat to post here. Nice work. Interesting your thoughts. Currently adding more resolution decreases the brushes area of influence, But read 3Dioots Ideas thread and see what you think about his thoughts about resolution being a brush based Idea with Voxels. I think its the way forward for this application. For voxel workflow to be less distructive to detail then Resoltion would need to be extremely high, This in itself is not a problem as a modern workstation can display up to 50 million voxel tri's easily, it is the manipulation of these large high resolution volumes that causes the problematic performance. Currently as Voxel volume resolution increases the brushes area of influence decreases meaning large manipulations become difficult or impossible. when a move is applied resampling has to take place. so rather than work to a Low res to high and back workflow something new has to be adopted. Making the brush engine level its influence rather than level the entire Voxel volumes resolution would mean that Large alterations can be made to high resolution volumes without dire resampling loss of detail. Quote Link to comment Share on other sites More sharing options...
Member Fabio Dona Posted August 12, 2009 Author Member Report Share Posted August 12, 2009 Thank you Leigh, I'm a little late in this reply but I think we have discussed the voxel sculpting issues in other threads by now... I think 3Dioots ideas are very good, but I'm still not sure what causes performance problems in 3d coat, maybe isn't volume editing at all, maybe it's the surface reconstruction and rendering after the editing that slows everything in higher resolutions. Maybe Andrew could say something about it... and adopt a proper solution... Faster brushes, or a faster render solution can lead to faster editing... or both. Here's another project that I started a few days ago, it was a very quick sketch, but I'm planning to finish it mostly in 3dcoat now. It's a version of Frank Frazetta's Death Dealer: Quote Link to comment Share on other sites More sharing options...
Taros Posted August 13, 2009 Report Share Posted August 13, 2009 Thank you Leigh, I'm a little late in this reply but I think we have discussed the voxel sculpting issues in other threads by now... I think 3Dioots ideas are very good, but I'm still not sure what causes performance problems in 3d coat, maybe isn't volume editing at all, maybe it's the surface reconstruction and rendering after the editing that slows everything in higher resolutions. Maybe Andrew could say something about it... and adopt a proper solution... Faster brushes, or a faster render solution can lead to faster editing... or both.Here's another project that I started a few days ago, it was a very quick sketch, but I'm planning to finish it mostly in 3dcoat now. It's a version of Frank Frazetta's Death Dealer: Really nice anatomy. I am interested in the final. Go on. Can you tell us, how much time you spend for this status? Quote Link to comment Share on other sites More sharing options...
Advanced Member JamesE Posted August 13, 2009 Advanced Member Report Share Posted August 13, 2009 Here's another project that I started a few days ago, it was a very quick sketch, but I'm planning to finish it mostly in 3dcoat now. It's a version of Frank Frazetta's Death Dealer: Nice work! Looking forward to seeing the final. Quote Link to comment Share on other sites More sharing options...
Member Fabricio Torres Posted August 14, 2009 Member Report Share Posted August 14, 2009 I told you it was fun Now finish something! hah As if I finish mines.... Quote Link to comment Share on other sites More sharing options...
