The 3D-Coat 4.5 normal map doesn't work in Unity!
Go to solution Solved by Silicon Power,
Unity should get you a fix normal message , just accept this and you are done.
OR
Double click on the normal map image , then state it as a normal map under its properties (texture type --> Normal Map) .
Edited by Michaelgdrs
