import without voxelizing problem
I have imported an object without voxelising, edited it, and then saved it. Everything works wonderfully, and I am very happy...
Unfortunately, when I close and then reopen the file, and edit the non-voxelised object, the mesh pulls apart (the fill and smooth tools, in particular, seem cause this). The attached image shows this phenomenon.
Am I doing something wrong?
3DC 3.5.11(GL)-64 Win7(64)
Thanks!
Thanks!
Try it again, perhaps. Yesterday, I had some similar glitches and had to resort to an autosave file to keep from losing the work I did. Never saw the problem again. It's one of those little aggravating things that crop up once in a while, and when you try to reproduce it (for bug report), it starts behaving correctly.
Hi AbnRanger, thanks for your reply. I had actually tried this many times, with many import filetypes, before I posted. This phenomenon appeared with all files except for the STL file. Unfortunately, even the imported STL file exhibits this after saving, closing, and reopening. I have attached another image, and If I could, I would attach the files in question.
  • 2 months later...
