Guest pnog Posted February 14, 2016 Report Share Posted February 14, 2016 (edited) Version: 4.5.19(DX64) Windows7 Home CPU: i7 RAM: 12Gb "Paint" room. I have 7 Layer Folders in Project, 20 layers each. Click Textures -> Export -> Export Layers w/ Depth, Color & Glossiness ALWAYS saved .color.psd, .specular.psd, and then Сrashes in a few seconds with Exception (mscoreei.dll , see attached screenshots). Edited February 14, 2016 by pnog Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 14, 2016 Report Share Posted February 14, 2016 Hi ! Could you please test it with the last version ? http://3dcoat.com/forum/index.php?showtopic=17076 ty ! 1 Quote Link to comment Share on other sites More sharing options...
Guest pnog Posted February 15, 2016 Report Share Posted February 15, 2016 (edited) Hi. Tested in 4.5.28(DX64). Unfortunately, the error persists: saved .color.psd (45Mb), .specular.psd(28Mb), and then Сrashes in a few seconds with Exception. But with other module Exeption: StackHash_3d4a, and by a second test - in 3d-CoatDX64S.exe, and by test 3 - in StackHash_3f4a (see screenshots). Update: The error occurs ALWAYS after EXACTLY 60 seconds ! Edited February 15, 2016 by pnog Quote Link to comment Share on other sites More sharing options...
Carlosan Posted February 15, 2016 Report Share Posted February 15, 2016 Model have any nGons ? Please send a support-related question, to Andrew Shpagin at support@3dcoat.com ty Quote Link to comment Share on other sites More sharing options...
Guest pnog Posted February 15, 2016 Report Share Posted February 15, 2016 No, model not have NGons. ONLY Triangles (not Quads). P.S. See important Update info in my previous message. Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted February 15, 2016 Contributor Report Share Posted February 15, 2016 Can you kindly upload the file so we can test , or export the textures for you so you can continue working? Quote Link to comment Share on other sites More sharing options...
Guest pnog Posted February 15, 2016 Report Share Posted February 15, 2016 Can you kindly upload the file so we can test , or export the textures for you so you can continue working? Sorry, I can not, because a commercial product. Quote Link to comment Share on other sites More sharing options...
Contributor Michaelgdrs Posted February 15, 2016 Contributor Report Share Posted February 15, 2016 No problem just trying to help you out. Quote Link to comment Share on other sites More sharing options...
Guest pnog Posted February 15, 2016 Report Share Posted February 15, 2016 No problem just trying to help you out. Thank you Michaelgdrs. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor digman Posted February 15, 2016 Reputable Contributor Report Share Posted February 15, 2016 Ok, just checking here, are you wanting to saved these layers to apply to another similar model as the tool tip reads or wanting to just export the texture maps to be applied to your model. Under the File Menu is where you export your textures. (Export Objects and Textures). Of course the above does not solve the problem you are encountering. I think Andrew would be the only person to solve that problem. Maybe you can get an NDA exception for Andrew the developer to look at the file layers exporting problem. Quote Link to comment Share on other sites More sharing options...
Guest pnog Posted February 15, 2016 Report Share Posted February 15, 2016 Ok, just checking here, are you wanting to saved these layers to apply to another similar model as the tool tip reads or wanting to just export the texture maps to be applied to your model. Under the File Menu is where you export your textures. (Export Objects and Textures). Of course the above does not solve the problem you are encountering. I think Andrew would be the only person to solve that problem. Maybe you can get an NDA exception for Andrew the developer to look at the file layers exporting problem. Thank you digman. I export for apply to another similar model. Of course, now I do it the other way, consistently exporting all necessary layers. That is the work goes on But with just one click (Export Layers w/ Depth, Color & Glossiness) it would be easier to do. Quote Link to comment Share on other sites More sharing options...
