Advanced Member do lo Posted April 12, 2016 Advanced Member Report Share Posted April 12, 2016 we should be able to rotate in the pose tool and cut tool and other tools besides the transform tool. Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 13, 2016 Reputable Contributor Report Share Posted April 13, 2016 we should be able to rotate in the pose tool and cut tool and other tools besides the transform tool. Have you tried to rotate using the Transform Gizmo? That's what it is there for...MOVE/SCALE /ROTATE Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 13, 2016 Reputable Contributor Report Share Posted April 13, 2016 ...This is the problem with the FEATURE REQUESTS section of the forum, in general. People naturally tend to make requests before they ask if such a feature already exists. That means Andrew or whomever monitors the feature requests has a hard time sorting through all of the request threads, since more than half are for things they are currently in or tasks that are already doable in the app Quote Link to comment Share on other sites More sharing options...
Advanced Member do lo Posted April 13, 2016 Author Advanced Member Report Share Posted April 13, 2016 (edited) ...This is the problem with the FEATURE REQUESTS section of the forum, in general. People naturally tend to make assumptions about something that they think they know what everybody else is talking about. duh, i can use the transform tool. im talking about the rotation in other than transform mode.. why should i have to leave my current tool to use translate to get the angle i want and then have to go into my previous tool,.? and sometimes this is not even possible. Edited April 13, 2016 by do lo Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted April 13, 2016 Advanced Member Report Share Posted April 13, 2016 The transform gizmo (note: NOT the transform "tool") IS available with the pose tool, you don't need to switch tools. I'm not sure what you mean by wanting to rotate with the cut off tool? Can you provide an example where that would make any sense? Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 13, 2016 Reputable Contributor Report Share Posted April 13, 2016 ...This is the problem with the FEATURE REQUESTS section of the forum, in general. People naturally tend to make assumptions about something that they think they know what everybody else is talking about. duh, i can use the transform tool. im talking about the rotation in other than transform mode.. why should i have to leave my current tool to use translate to get the angle i want and then have to go into my previous tool,.? and sometimes this is not even possible. Duh? You didn't bother to watch the video, did you? Quote Link to comment Share on other sites More sharing options...
Advanced Member do lo Posted April 25, 2016 Author Advanced Member Report Share Posted April 25, 2016 the video is way back from version 4.1, again out of date video. i dont get the same tool option tab as he does. Quote Link to comment Share on other sites More sharing options...
Advanced Member Gary Dave Posted April 25, 2016 Advanced Member Report Share Posted April 25, 2016 You're right, the tool options window has improved, but the video isn't showing you things you can't do any more, if you were to actually use the tools and try out different options you'd find that everything showin previously is still applicable. Try changing the transpose mode if you don't want it to be based on a line, try checking and unchecking the "use free form" or "regular gizmo" boxes for alternate ways to modify the selection. Just try things. 1 Quote Link to comment Share on other sites More sharing options...
Reputable Contributor AbnRanger Posted April 26, 2016 Reputable Contributor Report Share Posted April 26, 2016 the video is way back from version 4.1, again out of date video. i dont get the same tool option tab as he does. We are still in the V4 cycle, so how is a video for 4.1 "out of date?" There are no major changes since then, and as Gary said previously, "Rotating" your selection works the same way now, as in the video...regardless of any new parameters Quote Link to comment Share on other sites More sharing options...
