Real World Height Maps for Terrain Creation
digman
Terrain Party will create for you a nice downloadable height map from 18 km to a 8 km grid for a landscape base. The height map can be used in Unreal 4 and other rendering engines. World Machine can import the map for further work and Vue as well.
I currently use the height map in Vue, Unreal and 3DC for further work on the terrain after exporting from Vue. I then export a height map out of 3DC.
http://terrain.party/
Edited by digman
  • Like 4
Thanks for posting the link, David. Nice find.
However, I do have problems finding a region that I can download heightmap of. I tried parts of many European countries, but I only receive 1 KB zip files with a text file inside where they state that:
No height map data was available. That's a bummer.
If you're way at the poles, that's probably why. Orbital measurements only go
so far away from the equator.
If this area is filled with water, try a box that has less water. That's
probably a good idea for gameplay reasons anyway.
Otherwise, this could be a problem with terrain.party. Retrying the link above
at a later time might help, or try posting it in the Discuss link for help.
At any rate: there's no height maps here. Sorry!
Are there any locations that work?
OK, Paris and major cities do work, but the maps could be of better quality. They're good for base terrain shapes though.
Edited by ajz3d
What I found is that you need to be on the default map view, "MapQuest Street map" to get the data... I use the MapQuest Satellite map to get the terrain topology area I like, Then switch back to the MapQuest Street map. I had no problems so far in getting any data.
The data is good for a base terrain to further work on as stated. I like the natural forms of the topology you get to start with as a base. I use the merged file as it tends to be the best one. These height maps can be loaded in Vue or World Machine for further work. I get several terrain areas, save them out as obj files from Vue, Import them into 3DC, merge pieces together I like plus do more work on them using stencils. Once done bake for the final height map.
Update: You can increase the grid above 18km too...
Edited by digman
