Vector displacement
  • Please log in to reply
66 replies to this topic
#61 SonK
SonK
    Novice
  • PipPip
  • 464 posts
  • Gender:Male
  • Interests:3DCG!, video games.
Posted 10 May 2008 - 06:37 AM
I have updated the link. Now VD can be exported/imported as zero based. Several bugs was fixed.
Version identifier - 3.09 BETA3B+
thank you, this version is stable! i'm going to test the vector displacement export/import between Modo.
edit: i use the default setting when importing vector displacement, with a scale factor of 8-10 and it works nicely!
edit2: I saved out a vector displacement image from 3DC, brought it into Modo and it looks very good! make sure to set the low value to -100% and check on the material, and set the displacement distance to something like 80 mm(play around with this number).
3DC EXR exported via "Save Vector Displacement" and imported into Modo:
Posted Image
Only "issue" i see is that the output from 3DC EXR file is lighter, then Modo:
Posted Image
Freelance Character Artist
#62 rimasson
rimasson
    Novice
  • PipPip
  • 420 posts
  • Gender:Male
  • Interests:CG, photo, art, music, book, and movies.
Posted 10 May 2008 - 09:05 AM
One more thing :
On the top picture, i first sculpted a plane in sculpt mode, then draw a stroke with the pen tool. ( the purple stroke). This stroke is perpendicular to the sculped surface.
On the bottom pic, i imported a vector displacement map, then draw another stroke. This stroke is not perpendicular to the actual surface, but to the surface before i imported the vector disp.
Is it a bug ?
I've got a new bug:
Now, the stroke is perpendicular to the surface, but there's a kind of weave pattern on the stroke. It happens with all kind of tool : Pen, expansion, spline...
It appear on the part of the model displaced by the texture.
I imported the texture on a layer, deleted this layer, created a new one, but the bug is still there.
I happens only when i load vector displacement files.
When you load and save a vector displacement texture, could you also add a choice between 'Zero level is gray normalized or not'
and Zero level is gray or black, normalized or not when you load and save a simple displacement map (for all the layers or for the curent only )
Win XP 64 Pro
Inter Core 2 Duo , 6420, 2.13 Ghz
3.25 Go ram
Quadro Fx 1500
#63 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,836 posts
  • Gender:Male
Posted 12 May 2008 - 11:13 AM
I've got a new bug:
I have tried to reproduce... but failed. is it possible to get exr file?
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#64 rimasson
rimasson
    Novice
  • PipPip
  • 420 posts
  • Gender:Male
Posted 12 May 2008 - 12:38 PM
Here are the files.
Open the .obj plane, keep the Uvs
load the vector displacement on the current layer
paint depth using the pen tool for example.
Win XP 64 Pro
3.25 Go ram
Quadro Fx 1500
#65 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,836 posts
  • Gender:Male
Posted 12 May 2008 - 02:04 PM
Thank you! reproduced & fixed
www.3d-coat.com
#66 JPWestmas
JPWestmas
    Neophyte
  • Pip
  • 76 posts
  • Gender:Male
Posted 19 April 2012 - 08:18 PM
Maybe there is something more recent on this. Is there even a vector displacment capability in 3dc 3.7? Or is this on the back burner still? I just loaded a vector displacement from xnormal today into Modo 601, It works awesome!! Plus the match UV capability in xnormal saved me from doing a retopo.
http://forums.luxolo...id=65566&page=0
#67 carlosan
carlosan
    Master
  • Custodian
  • 5,411 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 11 August 2012 - 04:20 PM
Hello
Is there any tuto about vector displacement workflow with another apps ?
ty :)
My Blogfolio
Google+ link
3DC Google+ Community
