Vector displacement
  • Please log in to reply
66 replies to this topic
#1 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,837 posts
  • Gender:Male
Posted 05 May 2008 - 07:03 PM
I see that vector displacement is actually important...
Please tell me if LW accepts 16-bit RGB tif-s as a source of vector displacement.
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#2 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,589 posts
  • Gender:Male
Posted 05 May 2008 - 08:04 PM
Carrara 5 supports 16 bit rgb tiffs. I tested for displacement and it works.Carrara 6, another user of the upgraded version would have to check for you on that version. I having to dust off my lightwave hat and dig back into doing displacement better in it. Carrara works so well with displacement and normal mapping(baker plug-in for normal mapping) that I seldom use lightwave for displacemen
#3 tortoro
tortoro
    Neophyte
  • Pip
  • 40 posts
Posted 05 May 2008 - 09:25 PM
Hi,
I try both 16 bit and 32 bit in lightwave and it was loaded and applyed on my object head.
best regards
#4 goodrichm
goodrichm
    Neophyte
  • Pip
  • 98 posts
Posted 05 May 2008 - 09:54 PM
I'm still a noob at this, but some of the experts say that LW9 supports both 16bit & 32 bit TIFF displacement maps:
LW dispalcement talk on ZBrush forum
Attached is the LW9 node tree setup for ZBrush displacement maps as published by NewTek. Hope this helps...MG
<a href="http://www.voxengo.c...qq8bzWVD6"><img src="http://www.voxengo.c...fx/voxengo.png" width="180" height="60" alt="Voxengo.com" /> Pro AudioUnit and VST plugins</a>
Win 7 Ult 64bit
Intel Core 2 Quad Q9400 2.66Ghz 8GB RAM
nVidia GTS 240 2GB
#5 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 06 May 2008 - 07:18 AM
Of course, displacement along normal is what is working well even now. But I mean not normal displacement but vector displacement that contains not only grayscale, but also XYZ (RGB). How is it supported by LW, Carrara... Does it accepts tif RGB 16 as a source of vector displacement.
www.3d-coat.com
#6 rimasson
rimasson
    Novice
  • PipPip
  • 420 posts
  • Gender:Male
  • Interests:CG, photo, art, music, book, and movies.
Posted 06 May 2008 - 07:44 AM
I know only 3 rendering enghines that support vector displacement :
Mental Ray,
Modo
and Renderman.
That's a few, but a think that vector displacement will be more and more important in the future.
Win XP 64 Pro
Inter Core 2 Duo , 6420, 2.13 Ghz
3.25 Go ram
Quadro Fx 1500
#7 Sethren
Sethren
    Neophyte
  • Pip
  • 62 posts
Posted 06 May 2008 - 08:23 AM
As far as Modo goes these are all of the 2d image formats that Modo accepts so i would imagine 16bit color applies to the .TIFF, .PNG, .HDR and .EXR.
.BMP .JPG .JPEG .PNG .ICO .IFF .JNG .JIF .LBM .MNG .PCX .PBM .PGM .PPM .RAS .TGA .TIFF .TIF .XBM .XPM .WBMP .HDR .GIF Adobe PhotoShop .PSD EUlumDat .LDT .IES OpenEXR .EXR
#8 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 09:56 AM
I don't know how vector displacements works, but I think some really math driven node freaks can make a nodetree that makes vector displacement possible in LW. LW supports both 16bit and 32 bit tiff, hdr and open-exr file formats.
#9 SonK
SonK
    Novice
  • PipPip
  • 464 posts
  • Gender:Male
  • Interests:3DCG!, video games.
Posted 06 May 2008 - 09:57 AM
I believe Modo only uses OpenEXR file for vector displacement. Hopefully Andrew will support it in the future so i can take my vector displacement back and forth between Modo and 3DC :D
Freelance Character Artist
#10 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 10:22 AM
I just found out that there's a free plugin that makes it possible to do vector displacements in LightWave. So any file format LW can read can be used for vector displacement, so that includes both 16/32 bit tiff and openExr formats.
#11 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 11:02 AM
I got some tips from the plugin creator, which said that it's compatible with vector maps from modo, so for it to work with 3DCoat the vector displacement should work a bit like modo. Here's some tips he gave me. I hope it make some sense to you Andrew as I don't really understand a thing of this.
I think that it should work in tangent space (texture space),
it should measure the displacement delta vector (difference of position),
this can be rescaled by a user factor (Default = 1),
since it is coded in color like a normal map but should
works with negative displacements it need also a shift/rescale,
so a null displacement will be coded as a medium gray.
#12 yukon_28
yukon_28
    Novice
  • New User
  • PipPip
  • 152 posts
Posted 06 May 2008 - 01:49 PM
Andrew, i am so glad to hear that you started to work in this direction, Vector displacement its a way to go, i am sure, it is a future. All users of hi-end apps with MentalRay (integrated or stand alone), such as Max, Maya and XSI will be happy with this feature, and even renderers that does not have ability to use vector displacement now will get it in the near future i think, also i am sure this feature will make 3DC more attractive for new users looking for 3d sculpt\paint sw, because it is rare on the today's market. I am till not used vector displacement in MR, but in modo it make sense, great feature.
Yes, its would be great. BTW, i started to use modo a few weeks ago, and i should tell that i am just loving this program. Max still my main sw and i still like it and i think that Max with all its plugins its a most powerful "generalist" tool in the market, especially if you have no R&D department working for you to make custom tools as you need them, but many things is just so much easier and faster to do in modo :rolleyes:
#13 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 06 May 2008 - 02:34 PM
Does Modo/LW accepts word space or tangent space normalmaps?
World space is more easy to do because tangent space calculation metods are different.
www.3d-coat.com
#14 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 02:56 PM
LW prefer tangent space and it also works better for animation as tangent space normal maps also works with deforming objects when animating. World space normal maps is the worst as you can't rotate or animate object as the lighting will not appear correctly.
#15 yukon_28
yukon_28
    Novice
  • New User
  • PipPip
  • 152 posts
Posted 06 May 2008 - 05:24 PM
Yes, accepts. I'd agree with Ztreem, object-space normals maps are no-go, we need tangent space maps.
Andrew, i am not LW user, but i seen it in modo forum, might be interesting for you (plugin that adds vector displacement node to LW9):
http://pagesperso-or...al_Nodes_2.html
#16 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 06 May 2008 - 05:40 PM
I have made vector displacement import/export. Please test it because I have no application that can use it. I have trial of Modo 302 but I can't substitite map there (I never used Modo). The link is below:
http://www.3d-coat.com/files/3d-Coat-209B3B-en.exe
www.3d-coat.com
#17 yukon_28
yukon_28
    Novice
  • New User
  • PipPip
  • 152 posts
Posted 06 May 2008 - 06:05 PM
<a href="http://www.3d-coat.com/files/3d-Coat-209B3B-en.exe" target="_blank">http://www.3d-coat.com/files/3d-Coat-209B3B-en.exe</a>
I cant belive how fast you are... :blink: I'll try it now in modo, downloading.
#18 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 06:38 PM
Cool. Andrew you're fast. I'll download now.
#19 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 06 May 2008 - 07:00 PM
I have a question to LW users: I have imported object into Layout (sphere.obj) but I can't apply subdivision on it on render level (and on view level also). It looks rough and faced anyway. How should I do?
How to convert mesh to subpatches in Layout?
www.3d-coat.com
#20 Ztreem
Ztreem
    Neophyte
  • Pip
  • 97 posts
  • Gender:Male
Posted 06 May 2008 - 08:51 PM
There should be a button called G-Toggle Subpatch under the modeler tools tab that would make it to subpatches. If that doesn't work you have to load the object in modeler and press the 'Tab' key then save the object and load it into layout.
