3D-Coat 3.0 ALPHA
4486 replies to this topic
#121 splodge
splodge
    Apprentice
  • PipPipPip
  • 506 posts
Posted 10 September 2008 - 06:53 PM
Hi Andrew!,
Undo and Smooth seems to be broken in 'Draw with Pen' mode in the latest update.
I hit Undo and nothing happens. At other times undo will cause the entire model to vanish.
Holding the shift key for smooth operation doesn't seem to do anything but draw.
#122 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,814 posts
  • Gender:Male
Posted 10 September 2008 - 07:00 PM
Updated the link. Symmetry was forgotten. About undo & smooth - really it does not work in draw with ped & pinch modes. I will do it soon.
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#123 tree321
tree321
    Novice
  • PipPip
  • 450 posts
  • Gender:Male
Posted 10 September 2008 - 10:28 PM
Thanks again Andrew. Love these frequent updates to play with.Working on a Volume sculpt now, just need more detail tools to finish it.
#124 Juan Carlos Montes
Juan Carlos Montes
    Novice
  • PipPip
  • 445 posts
  • Gender:Male
Posted 11 September 2008 - 04:39 AM
Hi Andrew
I work like 2 hour with the beta here my progress and few bugs.
I found it a bit difficult to make small details, we are going to be able to subdivide the model? or that going to be in conjunction with normalmaps?
or ma bey am totally wrong lol.
Bugs
when I save the model an open it again, the Symmetry plane seam to be scale.
The Pinch tool it not working like it should be or mabey i doesn't notice in small areas. It doesn't have the Smooth option like the other tools.
The snake, spike curve, and merge tools are leaving artifacts when you use it with the Ctrl key.
Here is a video capture showing some of the bugs its like 56 megs i think.
<a href="http://screencast.com/t/cCyycyk6t" target="_blank">http://screencast.com/t/cCyycyk6t</a>
#125 blugenwitz
blugenwitz
    Newbie
  • 10 posts
Posted 11 September 2008 - 11:20 AM
I really hope that curve modeling will be expanded in v. 3. 3d Coat can be perfect tool for fast industrial design prototyping - cutting with curves its a good idea, but i think curves needs to be more like in illustrator or - better - like in rhino/moi. Now I, for example, can only draw circle and it cuts a shape. But I need it to make boolean intersect, or move it, or snap to something... But I'm really in this - and will watch this thread very closely. I know majority thinks about it as a free form modeling, but for hard surface prototype modeling, with this price, it will be a gem.
#126 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 11 September 2008 - 11:40 AM
Curves functionality will be improved very much. At least:
- multi - branced curves with shared vertices
- multi - profile curves - evry vertex in curve has own 3D profile, size, rotation
- procedural layers that consist of curves with boolean add/subtract
www.3d-coat.com
#127 BluEgo
BluEgo
    Novice
  • PipPip
  • 127 posts
Posted 11 September 2008 - 12:10 PM
I have updated the link (ALPHA-05). Actually this is result of one day work because today's work is essentially not finished. I worked over essential improving of transistion speed voxels<->surface but not finished.
Changes of current alpha:
1) Possibility to cut surface like a butter with rectangle/ellipse/curve as it shown below:
Posted Image
2) First results of surface approach - draw with pen and pinch tools. It is very easy to add full set thete - it will be done soon. But transition surface<->voxels is slighty long.
3) Many bugfixes, better look of red sphere.
About mac - all what is made is absolutely cross-platform, so there is no problem to compile on mac - only bureocracy - send sources to mac guy, put on server...
Maybe I will compile mac version soon also.
Great !
I am trying this alpha, is really funny :)
Anyway I think that, as you told, transition surface<->voxels could be very long on greater surface.
Is not t possible to make standard tools like pinch, pen and smooth working directly on voxels instead of on surface ?
#128 blugenwitz
blugenwitz
    Newbie
  • 10 posts
Posted 11 September 2008 - 12:22 PM
Thats great :)!
#129 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 11 September 2008 - 01:08 PM
Great !
The transforming of surface will be faster because it will be done only over dodified part of object.
www.3d-coat.com
#130 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 11 September 2008 - 01:09 PM
Link updated. Crictical bugs mentionad by Juan fixed.
www.3d-coat.com
#131 Dilla
Dilla
    Newbie
  • 18 posts
  • Gender:Male
Posted 11 September 2008 - 07:35 PM
Does that mean that volumetric sculpting will generally support layers?
#132 Christoph
Christoph
    Neophyte
  • Pip
  • 29 posts
Posted 12 September 2008 - 12:47 AM
Hi Andrew.
This Volumetric Sculpting is great even in this alpha stage. Good work!
I will like to know this please.
-Do you have plans to add multiple subdivisions like in poly-sculpting..?..So this way work big changes in the lowest subdivision and small details in the highest subdivision...
-Any news about the Move Brush, i`m waiting for that one.....?
Thank you very much and again good work!
#133 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,536 posts
  • Gender:Male
Posted 12 September 2008 - 12:48 AM
I may be misunderstanding one of Andrew's earlier posts. Am I to understand that switching between volumetrics and polys is there but just not fully functional (and I just don't know how to do it), or it's not fully functional yet, but it's also not yet in the versions we downloaded?
Phil Nolan
Generalist
#134 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,814 posts
  • Gender:Male
Posted 12 September 2008 - 05:25 AM
Hi Andrew.
Now I only know how to increase subdivision level. It is easy and I will make it soon. Decreasing is not so obvious...
About move - it is in process.
Now I am in a short trip, will be back sunday, so there is some small delay.
About surface/vox approaches - you are automatically changing approach while pressng buttons "Pinch" and "Draw" (surface appoach) and other (volumetric approach) Changing voxel->surface is immediate, surface->voxels takes some time.
www.3d-coat.com
#135 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,536 posts
  • Gender:Male
Posted 12 September 2008 - 05:53 AM
I noticed this during a test earlier today. I used Pinch to sharpen up an area, then when I went back to Carve it seemed to undo the pinch i just made.
Phil Nolan
Generalist
#136 rimasson
rimasson
    Novice
  • PipPip
  • 420 posts
  • Gender:Male
  • Interests:CG, photo, art, music, book, and movies.
Posted 12 September 2008 - 06:05 AM
The pinch act on the triagulated gometry created from the voxels, and pinch it.
When you return in voxels mode, the surface looks smoother, because of the voxel resolution limit.
Win XP 64 Pro
Inter Core 2 Duo , 6420, 2.13 Ghz
3.25 Go ram
Quadro Fx 1500
#137 SonK
SonK
    Novice
  • PipPip
  • 464 posts
  • Gender:Male
  • Interests:3DCG!, video games.
Posted 12 September 2008 - 06:44 AM
i do not like that behavior, because i feel like i have no control over my mesh. Jumping to voxel mode smooth it out..it kind of defeat the purpose of the pinch tool. Pinch area should stay the pinch.
One last thing. the Draw with pen tool, if you hold down Left mouse button over the same area it'll create a spike..that's gotta be a bug? I think it should be consistent like it was in last alpha. Currently, it'll be impossible to paint a level stroke across a mesh.
Freelance Character Artist
#138 3DArtist
3DArtist
    Apprentice
  • PipPipPip
  • 773 posts
  • Gender:Male
Posted 12 September 2008 - 07:41 AM
If i understand correctly, this is how sculpting acts in 2.10. It does make sculpting more difficult.
Intel Core i7-3770K
16GB RAM
GeForce GTX 570 2.5GB
Windows 7 Pro 64bit
web: gregcopin.com
#139 bobzilla
bobzilla
    Novice
  • PipPip
  • 169 posts
Posted 12 September 2008 - 04:44 PM
I thought it was just me doing something stupid!
I'm on a Mac so I haven't been able to play with the new alpha, but it definitely happens in Sculpt mode.
I haven't figured a way to control it either.
Basically, you just wind up making a porcupine!
#140 mAXWELL
mAXWELL
    Neophyte
  • Pip
  • 23 posts
Posted 12 September 2008 - 05:54 PM
Thanks for your effort!
