COLLADA Exporter
  • Please log in to reply
43 replies to this topic
#21 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 01 October 2008 - 07:37 AM
Are you running 2.10.10 ?
indeed... if it's of any importance or bearing, I've got .NET 2.0 installed on my desktop (not
sure which on the laptop)
perhaps someone else can test it too?
(can't imagine I've managed to screw up your install instructions that badly) :D
-portfolio-
Vista Ultimate SP1 64bit | Q6600 2.40 GHZ | 8GB RAM | Nvidia GTX 560ti
#22 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 09:21 AM
In the root folder there should be a file named Log.txt, can you have a look for the three entries
cMeshIO::AddCodec(): Added "Obj" mesh codec.
cMeshIO::AddCodec(): Added "Lwo" mesh codec.
cMeshIO::AddCodec(): Added "Fbx" mesh codec.
And there should be one just before that reads if the plug-in is being loaded
cMeshIO::AddCodec(): Added "dae" mesh codec.
#23 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 01 October 2008 - 09:56 AM
doesn't seem to be loading properly for me...the entry before those three is: Loaded image file "textures\vista3.dds"
(I can't find 'cMeshIO::AddCodec(): Added "dae" mesh codec.' in the text file)
anything hard-coded in the .dll in terms of paths? (cause I've installed 3dC into a c:\graphics\3d-Coat-2-10 path)
gonna sleep now, but I'll test more tomorrow.
-portfolio-
#24 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 10:34 AM
There's nothing hardcoded, and I've just uninstalled and re-installed into a similar location and it works fine.
Incidentally, what OS are you using ? I'm running XP SP2 and XP SP3 on my dev machines, I have another with Vista that I can try tonight to see if I can reproduce your problem.
Has anyone else tried the plug-in ?
Cheers.
#25 Andrew Shpagin
Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,813 posts
  • Gender:Male
Posted 01 October 2008 - 10:52 AM
It works well on last ALPHA. It creates DAE file with reference to texture.
Is there some viewer to look it rendered?
Is it possible to export with normalmap? I see it is referred in DAE file, but will it be accepted by external render?
Attention! If I have not answered on your question on your thread please write me to support@3d-coat.com. Sometimes I may loose the thread, so prease continue conversation with me via e-mail if you see silent. 3D-Coat on twitter
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#26 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 11:07 AM
I've got the Normal map included for the next build which I'll release tonight.
Try COLLADA Loader to view the file.
Cheers
James.
#27 Andrew Shpagin
Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,813 posts
  • Gender:Male
Posted 01 October 2008 - 01:31 PM
Cheers
James.
Exported files look fine with that viewer.
www.3d-coat.com
#28 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 01:37 PM
Thanks, and I've just updated the download to reference the normal map.
#29 Andrew Shpagin
Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,813 posts
  • Gender:Male
Posted 01 October 2008 - 01:55 PM
That viewer does not show normals... But I see changes in file structure.
www.3d-coat.com
#30 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 01 October 2008 - 05:56 PM
bizarre...still won't show up with Alpha18 (doesn't initiate in log.txt either).
I'm running XP SP2 (32-bit) and here's where I've got the .dll:
-portfolio-
#31 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 06:04 PM
I've got an old build of the Alpha that it doesn't show up in, I'll get the latest version and have a look.
Does it work with 2.10.10 ? If not, can you also try disabling your virus scanner when running 3DC (wild stab in the dark, but the scanner could be scanning the .dll as it's loaded and locking it).
#32 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 01 October 2008 - 06:10 PM
doesn't run with 2.10.10 either (and no-show in log.txt). no virus scanner when running 3dc, so that doesn't
appear to be it either...
I'll try it on my laptop with 3.0 alpha in a bit, but won't be able to check back in till later this evening.
Seems really strange that it's not being picked up by Windows as an optional pulldown (since you can see
I haven't bungled placing the .dll in the appropriate folder :D )
-portfolio-
#33 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 01 October 2008 - 06:19 PM
I'm out of ideas I'm afraid, it works on Alpha18 for me as well.
Andrew, have you got an idea on the problem ?
EDIT : Andrew would the VS2005 Redistributable Package be needed ? I don't know about this, but the common denominator on both my machines is VS2005 - only a thought.
#34 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 01 October 2008 - 06:25 PM
just to make sure I could operate with .dae, I took my test object I gave you into Ultimate Unwrap 3d and
saved it out as .dae ... and then re-imported it back into UU3d as .dae (and it retained all properties of its
original .obj format)
I'm outta ideas too, sadly ... hopefully others won't run into this problem if they need .dae <shrugs>
*edit* Just installed the 2005 visual c++ redistributable and re-booted, but still no-go for both 2.10.10 or
3.0alpha18 .... pulldown option on export just shows .lwo and .obj :(
-portfolio-
#35 Andrew Shpagin
Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,813 posts
  • Gender:Male
Posted 02 October 2008 - 08:32 AM
I have looked dll's contence and it refers to
MSVCP90.dll
MSVCR90.dll
It seems DLL is compiled and MFC libraries are not linked statically. JamesH, please check it in options.
www.3d-coat.com
#36 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 02 October 2008 - 09:56 AM
MSVCP90.dll
MSVCR90.dll
Not really knowing too much about this topic, I recompiled using the /MT option and checked the .dll with DependencyWalker and it seems to be ok now - is there anything more for me to do ?
I've uploaded a new build.
#37 Andrew Shpagin
Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,813 posts
  • Gender:Male
Posted 02 October 2008 - 10:17 AM
I have checked - it does not depends on VS DLL-s now.
It is interesting, have you succeed with normalmap exporting and rendereing?
www.3d-coat.com
#38 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 02 October 2008 - 10:27 AM
To be honest the only package I have that can display the normal maps is C4 and the normal map imports fine into it, I used the <bump> element tag to identify the normal map texture. Although that tag isn't listed in the COLLADA spec and after going through a lot of the COLLADA examples it's a bit vague on identifying what the normal map references need to be. Each package seems to use a slightly different way to identify actual textures. I'm going to have a look this weekend and maybe post on the COLLADA forums so that I can get a definitive answer.
#39 JamesH
JamesH
    Neophyte
  • Pip
  • 25 posts
Posted 02 October 2008 - 11:21 AM
In fact the bump extension is not supported by 1.4.1 or 1.5 and is discussed here, but it has been added as part of the Max extensions in the COLLADAMAx exporter from FeelingSoft, discussed here.
#40 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 02 October 2008 - 06:24 PM
thanks Andrew and JamesH, the dependence on those MSVC .dll seems to have been the issue.
I'm now able to see the .dae option (and consequently export, woohoo!) :)
-portfolio-
