3D-Coat 3.2 updates thread.
  • Please log in to reply
438 replies to this topic
#1 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • PipPipPipPipPipPip
  • 6,837 posts
  • Gender:Male
Posted 27 January 2010 - 07:29 PM
Posted Image
I will post all updates in this thread.
Download links:
With CUDA, 32 bit
With CUDA, 64 bit
Without CUDA, 32 bit
Without CUDA, 64 bit
OSX Version:
www.3d-coat.com/files/3D-CoatV32-11.dmg
Linux version:
http://www.3d-coat.c...-V3-2-11.tar.gz
Changelog:
3.2.11
- At least I solver issue with external normalmap. I am leaving external normalmap layer unmodified (even besides islands) and applying it after creating on-the-fly padding. It gives much better output quality for the pipeline [import exteral normalmap->add details/heal/correct->export modified map].
- Possibility to smooth with shift over seams on normalmap layer. This feature was there before but worked not well. Now it works really clean and you can even soften sharp edges on the model with this tool. Also it is easy to remove seams over normalmap.
- Possibility to pan in texture view with SPACE as in Photoshop. You should choose 3D-Coat preset from [Camera] menu.
- Drawing with CAPS LOCK will hide cursor only while painting, not always. It improves precission of painting and gives better control.
- If you are in custom pivot point mode "Frame" command will move pivot point to the center of the object (and framing itself of course).
3.2.10
- measurement tool in voxels.
- I improved 3D grid essentially. It can be customized to work with real units. 3D-Coat will be ready much better for precise works.
- Voxel primitives will follow grid points while moved with SHIFT (use CTRL, CTRL+SHIFT for smaller step of movement)
- There was problem with scale of quadrangulation in recent build. It is fixed.
3.2.09
- I made possibility to measure and define everything in Voxels using physical units like inches or meters. It was longstanding request, at least I done it. It is extremely useful for real production and prototyping.
- I hope that I succeed with exporting Ptex to Renderman. At least Renderman's utility ptxview displays 3D-Coat's ptx files correctly.
- I made special simple method for external programmers to make connector between 3D - application and 3D-Coat. I hope many connectors between 3D-Coat and different applications will be developed soon. I will post full description of the pipeline in a couple of days.
- Quadrangulation quiality and speed improved. Don't expect edgeloops but it is better then it was.
- I fixed several problems with STL export/import
- I resolved object/materials palette constant duplication problem if it is not docked.
- I restored checked "Use source positions" in export dialog for perpixel painting. It is necessary if you want to export model that was subdivided, painted and uv was changed. In this case it was impossible to export coarse (unsmoothed) low-poly object.
- I made possibility to create/install 3d-coat extensions from File menu. Extension may contain any sort of files - shaders, pens, strips, materials, masks etc. It is just image of additional files in coat's folder. It is good method to share 3D-Coat's content.
- At least I made expansion pack using Oliver Thornton's textures and pens in new format (3dcpack) that is cross platform and easy to use. He sent me tons of really cool stuff (great masks and skin textures, pens) and at least it will be published to community. Thank to Oliver! There is the link to package:
http://www.3d-coat.c...OT_Pack.3dcpack
Use File->Install extension to install package.
3.2.08 [beta]
- Much much better correspondence between Voxel room and baked color in Paint room.
- Problem with incorrect "Framing" work in voxel tools solved.
- Framing improved - you can focus on object or on pen position (scaling depends on radius in this case)
- I have made command that is very useful when you have very many objects in scene - combine current layer with all children layers.
- Pick tool for voxels. It is very helpful if you have many layers and want to select current object visually without VoxTree
- Fixed Voxels->Ptex merging, multiple ptex objects merging.
- I have done very longstanding request from SL community - support of multiple SL objects in scene.
3.2.07 [beta]
- Solved most longstanding problem - jagged strokes in paint modes (see http://bit.ly/aiw8u8 for reference).
- Fixed incorrect work of ApplyUV command over some models especially in microvertex mode problem referred there - http://bit.ly/cylc4A ).
- Upload screenshot bugs fixed
3.2.06 [beta]
- Lines/curves in 'E' panel will not dive into surface in Voxel mode too (in the same way as in Paint tab now)
- I (and webmaster) made useful feature for 3d-coat experience exchange-quick making of screenshots from 3DC shell and hosting on our server. In so way it will be possible to post screenshots with text very quickly. It was relatively easy to do on my side.
- Merging voxels->ptex fixed.
- I have add metadata record from http://bit.ly/aN7nVX for compatibility with Renderman.
- I improved 3DConnexion support, I hope drifting issue will be fixed. 3DC will perform calibration during start. But 3D mouse should be untouched during 3D-Coat's start, otherwise drifting will appear.
3.2.05 [beta]
- Ptex import when separate textures are assigned to initial faces before subdivision (not to subdivided faces).
- Ptex files export/import in new Ptex representation (texture per non-subdivided face)
- Dynamic Ptex resolution is done in new approach - one texture per non-subdivided face.
- support of merging multiple objects/deleting part of objects in Ptex representation.
- I checked that ptx files exported from 3D-Coat are correctly rendered in external renderer. Of course I made only simplest tests.
- Splines/Lines in E panel will not dive into surface in paint room. In so way you can easily draw over curved surfaces.
- solved longstanding problem with licensing when license file gets corrupted randomly (and rarely) in the middle of the work.
3.2.04 [beta]
- Ptex export/import done. You will be able to export/import color/specular/displacement separately. Ptex files are much closer to textures so I placed export/import ptx files in Texture menu
- Merging retopo room with reference mesh/painted mesh -> per pixel painting will respect color of the reference/painted mesh. In previous builds normalmap was baked correctly but color was not baked t per pixel painting if reference mesh was used.
- In Retopo->select tool Relax will act only on vertices selected in Retopo->Select->Verices. Snap button will work in the same way.
- Fixed render problem when rendering custom size frame was not properly centered.
- I fixed multiple problems with snapping in retopo tool. Problems was especially visible on the "creature" model.
- I fixed issue with crash in Linux while using 'V' key.
- I improved cylinder-like manipulator to avoid controls squashing.
- Fixed PSD export issue - incorrect (dotted) padding.
3.2.03 [beta]
- I made much much better algorithm for limit subdivision surface directly after importing model for microvrtex painting and Ptex. Model after import will look much closer to the limit subdivision surface.
- Increase resolution in Ptex improved - faster and more efficient. Expand/contract selection is add to this tool.
- Many small improvements inside Ptex - displaying textels count, better management of local subdivision.
- better padding for PSD files export
- Fade on edges in pen options will act on all pens simultaneously
3.2.02 [beta]
- First version of Ptex implemented. Supports export/import in standard formats, ptex files export/import is not supported
- possibility to change local resolution with Ptex.
- support of big 3B files to open (>4GB)
- Normalmap strength in per-pixel mode can be corrected with Depth modulator slider in layer blending panel
3.2.01 [stable]
- Selection opacity slider was add to pose tool.
- Eraser will lower normalmap strength when applied over the normalmap layer.
- Rectangle selecton with depth limitation will work in ortho mode too.
- fixed important linux/mac issue - adding multiple layers while exporting vector displacement. Sometimes adding layers can happen on Win too.
- Missing bronze shaders recovered
  • Javis likes this
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#2 mwgrafx
mwgrafx
    Novice
  • PipPip
  • 102 posts
  • Gender:Male
Posted 27 January 2010 - 10:38 PM
WOW! Didn't you just release 3.2 like 2 days ago! Nice update.
#3 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 28 January 2010 - 11:23 AM
Linux version uploaded too
www.3d-coat.com
#4 Digital777
Digital777
    Novice
  • PipPip
  • 476 posts
  • Gender:Male
Posted 28 January 2010 - 02:02 PM
Very cool, im thinking the 3.2 posts should be sticky/pinned posts now as it could look like 3.1 is the latest otherwise if people posted other topics. :)
#5 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 28 January 2010 - 03:07 PM
Question: Are we going to have to enter our email to download updates every time now?
Phil Nolan
Generalist
#6 Digital777
Digital777
    Novice
  • PipPip
  • 476 posts
  • Gender:Male
Posted 28 January 2010 - 05:13 PM
Thanks for making this a sticky/pinned post now :)
#7 splodge
splodge
    Apprentice
  • PipPipPip
  • 506 posts
Posted 28 January 2010 - 05:30 PM
You scared of rubbing the letters from your keyboard? :unsure:
#8 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,246 posts
  • Gender:Male
Posted 28 January 2010 - 06:16 PM
It is not mandatory. ;)
Lest limbs be reddened and rent--I spring the trap that is set--As I loose the snare you may glimpse me there--For surely you shall forget
"The Wind In the Willows", Chapter 7 "The Piper at the Gates Of Dawn"
#9 Giuseppe
Giuseppe
    Novice
  • PipPip
  • 227 posts
  • Gender:Male
Posted 28 January 2010 - 10:17 PM
2 days from release 3.2 .......... and now release 3.2.1 .... simply amazing Andrew, You work day and night on development of the program, You work hard, andrew you have all my respect development at the speed of light
Giuseppe Albergo, CG Artist
Posted Image
#10 amcmahon
amcmahon
    Neophyte
  • Pip
  • 42 posts
Posted 28 January 2010 - 11:59 PM
Hey Andrew, great work on another amazing update. I think I ran into a bug however with the latest update. I used to be able to increase resolution of a voxel mesh without having it decrease in size using either the quick button at the bottom of the layer section or the voxels tab up top. Every time I try it now it shrinks the object in half.
Any one else encounter this? I'm testing it on an older mesh of mine so I'm going to run a test with newly created primitives and see if I get the same result.
*Updated* Turns out only one of the layers in my Voxtree was having this problem. Not sure why but cloning it and deleting the old one fixed the issue.
Andrew, if you'd like the file for debugging just let me know.
#11 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 02 February 2010 - 08:50 AM
I just came looking to see why it's been so long since the last update and found it's been less than a week. :rofl: 3DC is like digital crack.
Phil Nolan
Generalist
#12 Lawless
Lawless
    Neophyte
  • Pip
  • 37 posts
  • Gender:Male
Posted 02 February 2010 - 11:51 AM
Yeah, isn't it crazy? Andrew when you release every week to two weeks, it gets us all totally hooked.
Andrew must be fiddling around with Ptex, seeing how to fit it in, seeing where it can take 3D-Coat.
Mmmmm.
#13 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 02 February 2010 - 12:03 PM
Yes, if you have seen the Twitter feed it seems like some progress has already been made.
Phil Nolan
Generalist
#14 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,837 posts
  • Gender:Male
Posted 02 February 2010 - 08:26 PM
Updated to 3.2.02 [beta]
Linux version coming soon.
It could be good to test how exported objects will look in other packages.
www.3d-coat.com
#15 philnolan3d
philnolan3d
    Master
  • Moderator
  • 6,544 posts
  • Gender:Male
Posted 02 February 2010 - 09:08 PM
Wow the Ptex detail looks really nice!
Phil Nolan
Generalist
#16 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,246 posts
  • Gender:Male
Posted 02 February 2010 - 09:15 PM
I made a quick test from a quadrangulated mesh and merging is perfect on my side,no artifacts anywhere on mesh.
Much better than microverts.
Very fast also.
Shader bump does not get baked although,only color.
(When and If you fix this,would you be able to bake shader bump to its own layer instead of layer1,I mean separate shader bump from main displacement ? )
#17 polyxo
polyxo
    Apprentice
  • PipPipPip
  • 745 posts
  • Gender:Male
Posted 02 February 2010 - 11:27 PM
This looks very good! Here is a quick test-object exported to Rhino and rendered with Maxwell.
#18 3DArtist
3DArtist
    Apprentice
  • PipPipPip
  • 773 posts
  • Gender:Male
Posted 02 February 2010 - 11:28 PM
Played with Ptex for a bit and :yahoo:
Can't wait to get some more time to really start using it.
Intel Core i7-3770K
16GB RAM
GeForce GTX 570 2.5GB
Windows 7 Pro 64bit
web: gregcopin.com
#19 Maximus3D
Maximus3D
    Novice
  • PipPip
  • 149 posts
  • Gender:Male
Posted 03 February 2010 - 02:42 AM
Am i the only one who have major lags in 3DC when using the paint tools ? they're so slow i cannot even make one single stroke without waiting for 3DC to update the stroke on the model, and when it finishes the stroke it looks like a dotted line. :( same problem in both DX and OGL versions. I never had these issues before, it's only now in the latest versions. And it's on lowpoly objects too, no highpoly stuff.
/ Magnus
#20 splodge
splodge
    Apprentice
  • PipPipPip
  • 506 posts
Posted 03 February 2010 - 02:58 AM
/ Magnus
I've also noticed surprisingly slow brush strokes when dealing with large textures. I've not done any tests to see if it's a problem with the more recent versions of 3D Coat.
Could it be that you've just never tried painting on a high res texture until recently?. Have you actually tried going back to an older version of 3D Coat and painting on a high res texture?.
I'll be interested to see if things have become slower.
But for now I'm off to test Ptex!..
