3D-Coat 3.5 updates thread
2405 replies to this topic
#601 philnolan3d
philnolan3d
    Master
  • Moderator
  • PipPipPipPipPipPip
  • 6,554 posts
  • Gender:Male
Posted 30 December 2010 - 08:36 PM
Is it possible to add instances along a path or surface of another object? If not, I'll add a feature request in the appropriate forum...MG
I think you should be able to add instances on the surface with the Merge tool and the On Pen option. I haven't tried that but it should work. Could be handy for adding very details bolts or rivets maybe.
I just noticed that Cut & Clone also makes instances, maybe other tools as well. This is great but you have to be careful. When you check that instances box on the merge panel it stays checked for that tool and all others. SO if you use it to merge then later use Cut & Clone it will be already checked.
Phil Nolan
Generalist
#602 erklaerbar
erklaerbar
    Novice
  • PipPip
  • 279 posts
Posted 30 December 2010 - 09:04 PM
ah yes, the instances want some multiplication controls. I thought that too. You could even think of a instance based l-tree generator, or a 3doat-tree edition with voxel instancing :brush:
BTW how do we use instancing? Is it useful more for rendering in 3DC?
#603 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 30 December 2010 - 10:07 PM
The right question.
1. I always PM to Andrew asking to think about more options in internal renderer. Could be used as an excellent tool for illustrations. (like zbrush)
2. Now we're talking about how to export this. Well, to have a conceptual fine sketch is always helpful. Just retopo the parent mesh and redo similarly in your favorite app. What else?
3. Some great help for mac users as they have a 32 bit app only in hand. So some cases found a possible solution for me.
MACOSX,
3DC bug reports here:
http://www.3d-coat.com/mantis
#604 AbnRanger
AbnRanger
    Master
  • 6,489 posts
  • Gender:Male
Posted 31 December 2010 - 04:38 AM
Just downloaded the latest and still have the scale issue. I will send you, Andrew, a sample file.
+1...I'm still getting the same thing as well. It doesn't do it all the time...just randomly. It's critical enough that I have to re-install 3.5.07, as it effectively shuts down both caching and multi-res capability (or risk losing your work)
#605 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 09:19 AM
Linux build uploaded.
But it looks like 3.5.08B has serious problems with caching as reported.
It is easy to avoid both problems that are most critical:
- select volume before un-caching
- don't select invisible layer before saving
I will reupload al versions again soon (today).
www.3d-coat.com
Frequently asked questions
Brushing improvements thread
#606 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 11:10 AM
Updated to 3.5.08C (Win+Mac)
changes since 3.5.08B:
- proxy problem finally solved
- voxtree problem reported by Phil fixed
- instancung works with Axial and Wrap tools
- highlight problem fixed for OSX
Linux - I hope today, probably a bit later.
www.3d-coat.com
#607 wave of light
wave of light
    Novice
  • PipPip
  • 437 posts
  • Gender:Male
  • Interests:3D, Print, Design, Family and Football
Posted 31 December 2010 - 11:45 AM
Thanks for the updated version Andrew.
I'm having major problems trying to export a very simple voxel sculpt (which has been retopo'd) using Merge to MV (PPP). Will give it a go in the new version and see if it works.
Cheers,
Ricky.
Sketch page inc New 'Thing' WIP
rsldesigns.co.uk (my website)
Posted Image
System Spec: Asus P5KC MB : Q6600 @ 3Ghz (OC) : 8G RAM : GeForce 9500 GT : Win7 64Bit
#608 erklaerbar
erklaerbar
    Novice
  • PipPip
  • 279 posts
Posted 31 December 2010 - 12:02 PM
thank you for the update, instances are fun. It makes Warp and Axial way more powerful! Would it be difficult to implement for axial and warp tool a step size and step rotation control? This way each step is for example 90% size of previous instance. Hexagon has something similar and i love it.
#609 Hirazi Blue
Hirazi Blue
    Neophyte
  • Pip
  • 34 posts
  • Gender:Male
Posted 31 December 2010 - 12:32 PM
Thanks, Andrew :good2:
#610 blobby
blobby
    Neophyte
  • Pip
  • 26 posts
Posted 31 December 2010 - 01:40 PM
Hi!
Some notes about 3.5.08C CUDA DX64 version on Windows7 64bit / Geforce 470 / 260.66 drivers:
Voxels:
- Resample. Default settings, make density 0.8 (or something else does not matter)
- Then undo, then redo
- Dimensions of voxel volume is decreased, i.e. it gets smaller in the scene
- This happens in inverse manner when you increase the detail, redo makes voxel volume bigger
Viewport / panel docking issue:
- Float shaders panel (or any other I think)
- Try to dock next to panels on right edge
- Panel docks, put strange buggy strip is introduced, shows a part of viewport and button
- Maximize 3D coat window (this fixes it, but doesn't prevent it), shaders panel docks back to right edge as a tab (next to brushes)
- This worked OK in 3.5 for me. Happens with 260.99 and 258 driver versions in 3.5.06 and 3.5.08
#611 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 02:08 PM
Please explain, I tested it, but have not found problems there.
www.3d-coat.com
#612 wave of light
wave of light
    Novice
  • PipPip
  • 437 posts
  • Gender:Male
Posted 31 December 2010 - 03:55 PM
Hi Andrew,
I think I've found the problem...
Here is what I'm trying to do:
1. Voxel sculpt (simple sculpt)
2. Into Retopo room. Create retopo mesh.
3. Still inside Retopo room, mark seams for uv and unwrap
4. Save
5. Go to Retopo menu and select Merge with NM
6. Bake local occlusion on, rays at 20.00000
7. If I select anything other than the default from the subdivide menu, it crashes 3DC
However, after further testing, I found that if I subdivided whilst in the Retopo room, before using the Merge with NM command, then I have no issues.
Further notes... I have nothing in the paint or sculpt room when trying this procedure.
Regards,
Ricky.
Posted Image
#613 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 04:27 PM
Hi!
Voxels:
ok, fixed it.
www.3d-coat.com
#614 feibe
feibe
    Newbie
  • 10 posts
  • Gender:Male
Posted 31 December 2010 - 05:16 PM
Thanks Andrew. Happy New Year!!
#615 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 05:35 PM
Hi Andrew,
4. Save
Regards,
Ricky.
Thanks, that bug was really important to be fixed.
Squashed it. I like reproducable bugs :)
www.3d-coat.com
#616 wave of light
wave of light
    Novice
  • PipPip
  • 437 posts
  • Gender:Male
Posted 31 December 2010 - 05:40 PM
Thanks, that bug was really important to be fixed.Squashed it. I like reproducable bugs :)
No problem Andrew.
I always look at any problems in detail before declaring them a bug. Thank you so much for fixing it so quickly. I will test it when the new version is ready.
So, am I right in thinking that using the 'subdivide' menu from the Merge with NM command will only subdivide the texture for the paint room and not the retopo'd mesh (which is what I had to do before as a work around)?
Cheers,
Ricky.
Posted Image
#617 Andrew Shpagin
    3DC creator & admin
  • 3D-Coat Developer
  • 6,847 posts
  • Gender:Male
Posted 31 December 2010 - 05:43 PM
No problem Andrew.
Cheers,
Ricky.
It will subdivide mesh too, but you will be able to export non-subdivided mesh too from export dialog.
www.3d-coat.com
#618 wave of light
wave of light
    Novice
  • PipPip
  • 437 posts
  • Gender:Male
Posted 31 December 2010 - 05:46 PM
Thanks again Andrew. I have to say, just for the uv unmapping 3DC is amazing. Now that I'm getting the hang of voxels and retopo I know I will end up using it more for model creation than other packages.
Regards,
Ricky.
Posted Image
#619 michalis
michalis
    Expert
  • PipPipPipPipPip
  • 2,479 posts
  • Gender:Male
Posted 31 December 2010 - 07:21 PM
3.5.08b, 3.5.08c, mac builds.
Strokes and loop guides in topo room are broken ! A serious bug. Reported.
MACOSX,
#620 AbnRanger
AbnRanger
    Master
  • 6,489 posts
  • Gender:Male
Posted 01 January 2011 - 03:32 AM
Thanks for working hard on this, but I am still having the cached object arbitrarily scale...I'm usually in volume mode when I cache it (3.5.08C). It seems like the camera zooms in on it's own when caching, but it's actually 3DC scaling the object. It happens randomly. As soon as I try to capture in on video, it plays nice for a bit.
