Maya AppLink
  • Please log in to reply
32 replies to this topic
#1 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 30 October 2010 - 07:56 PM
Hi guys.
Here is my small contribution in 3DCoat. =).
You can also watch preview-tutorial, how to use it
http://vimeo.com/16338694
I created Trello board where you can see status of progress, bugs, ideas and etc.
Join this group to make applink better and bring your own ideas.
Latest version: 2.0a1
Supported Maya: 2008-2013.5 (32/64) win/linux/osx
Change Log:
version 2.0a (!!! New version requires a clean installation.)
New:
- Added support for the latest applink specifications.
- New GUI, shelf, some of icons were repainted.
- All setting now are in c:\Users\XXX\Documents\applinkMayaCoat.cfg file. So you can make import/export from shelf or UI, all paths in UI will be passed correctly.
- Supporting 3d-Coat V3/V4 (see tab 'Options'->3D-Coat[Vn])
- New maps SpecColor/Emissive/EmissiveColor.
- Improved compatibility with Maya 2013/2013.5
Notes: Currently 2.0a is on a beta stage. Needs to be proper tested. UI elements in Options tab look messy. Applink 2.0 doesn't work with Maya 2008-2009 at this moment.
version 1.06
New:
- Added compatibility with some features of AppLink rev.1.2/1.3 ("export as a curve profile" and "export as single voxel object")
- Added direct export from 3D-Coat->Maya via "Export to->Maya". To initialize this ability, you have to run Maya AppLink at first. All needed settings will be created automaticaly for 3D-Coat.
Improved:
- You can keep a few objects in scene and export/import them one by one, or all at once. Importing mechanism has optimization algorithms and useless shaders (without connection with mesh) will be removed automatically from scene, for performance purposes.
- Workflow was improved. You don't need create shaders for brand new objects before exporting.
- Stability has been improved.
version 1.05.1
- fixed workspace path
- fixed ui bug in Maya2011
version 1.05
- For better projects organization all export/import files from 3Dcoat are located now in subdirectory "3dcoat" of current Maya project;
- Fixed some significant bugs with paths;
- Removed scripts files. All code has moved to plug-in file;
- Fixed shelf commands.
P.S. Before install it, please clean up old files.
version 1.04
- Fixed UI bug with import dialog (Linux);
- Fixed object's name(s) after import into Maya;
version 1.03
- Fixed using project folder "default" for export geometry;
version 1.02
- Porting plugin's code to Python. Now, it's got cross-platform compatibility with Linux and OSX;
- Some bug fix;
Edited by Styler, 04 June 2013 - 10:41 PM.
upgrade to version 1.06
#2 Taros
Taros
    Expert
  • Moderator
  • PipPipPipPipPip
  • 2,936 posts
  • Gender:Male
Posted 19 October 2012 - 12:10 PM
There is something wrong with maya applink and v4. Could you check this please?
#3 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 23 October 2012 - 03:00 PM
I'm working on it. Update will be available soon.
#4 Taros
Taros
    Expert
  • Moderator
  • PipPipPipPipPip
  • 2,936 posts
  • Gender:Male
Posted 23 October 2012 - 08:04 PM
Great! Thanx!
#5 v_m
v_m
    Newbie
  • 8 posts
Posted 09 December 2012 - 02:53 PM
Applink for maya 2012 x64 worked fine until yesterday... weird enough, today it loads the plugin, but it fails to read any proc. ex: Error: Cannot find procedure "_3dcoatUI". And so on, for all procedures. It makes no sense, it's like twilight zone... So I've overwritten the old py file with a 'fresh copy', in bin/plug-ins, nothing. Since this is a python script I have no idea what's going on with it. : <
and... PS: 2013 support pls, if you have the time... thanks! :)
#6 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 10 December 2012 - 01:19 AM
New plugin will be released soon, in during 2 weeks.
This usually means that plugin itself is not loaded. Check it status in plugin manager.
Edited by Styler, 10 December 2012 - 12:55 PM.
#7 wailingmonkey
wailingmonkey
    Apprentice
  • PipPipPip
  • 701 posts
Posted 10 December 2012 - 08:14 AM
Looking forward to that, thank you Styler! :)
-portfolio-
Vista Ultimate SP1 64bit | Q6600 2.40 GHZ | 8GB RAM | Nvidia GTX 560ti
#8 buexe
buexe
    Neophyte
  • Pip
  • 28 posts
Posted 27 December 2012 - 04:09 AM
Hey, I am on v4 beta and there this menu item "open in original app" isnt there anymore. Anyone know how to get stuff from 3dcoat to Maya via appLink? Also wanted to mention that I have a background in Maya API stuff ( Python and C++ ) so if there is anything I can help out with, please let me know.
#9 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 29 December 2012 - 03:54 AM
Version 2.0a has arrived. Happy New Year for everyone!
#10 buexe
buexe
    Neophyte
  • Pip
  • 28 posts
Posted 01 January 2013 - 08:50 PM
Did a quick test and export/import worked right out of the box! Thank you so much!!! And happy new year to you as well!
#11 Anthony Thomas
Anthony Thomas
    Newbie
  • 2 posts
Posted 06 March 2013 - 12:28 AM
Hi a few things.
I have a prop I am trying to unwrap, when I use this script. I check the box that says, "Perform UV-Mapping in 3DCoat" (checkered icon), when I check that on an object on my prop (which has multiple objects)
I get this error.
[ref] mode
// Error: line 1: line 1: No object matches name: .color //
// Error: line 1: line 1: No object matches name: .ambientColor //
// Error: line 1: line 1: No object matches name: .normalCamera //
export complete
// Error: line 1: AttributeError: file C:/Program Files/Autodesk/Maya2013.5/bin/plug-ins/3dc_connector.py line 1000: 'module' object has no attribute 'MStatus' //
What do the first 3 lines mean?
Either way it works...I loads up in 3DCoat.....So now I do all my unwrapping in, and save the UVS, and go to File> Open in original app
Now when I bring a piece of my prop back in, I chose the IMP icon on my 3DCoat tab, and all the options are checked. I choose ok, and my object is imported.....however....every other geometry in my scene dissapears, and is no longer in my outliner, every object, other than the one I brought in from 3Dcoat just GONE......WTH is that all about?
This is the message I get once I import my object back in from 3DCoat using your script.
C:/Users/Owner/Documents/maya/projects/default/3dcoat/import.obj
Import: can't parse SG
// Error: line 1: AttributeError: file C:/Program Files/Autodesk/Maya2013.5/bin/plug-ins/3dc_connector.py line 1053: 'module' object has no attribute 'MStatus' //
# Error: RuntimeError: file C:/Program Files/Autodesk/Maya2013.5/bin/plug-ins/3dc_connector.py line 641: Error occurred during execution of MEL script
line 1: AttributeError: file C:/Program Files/Autodesk/Maya2013.5/bin/plug-ins/3dc_connector.py line 1053: 'module' object has no attribute 'MStatus' #
Thanks,
Little frustrated, and lost on the matter.
#12 pixeldroid
pixeldroid
    Newbie
  • 12 posts
  • Gender:Male
Posted 08 March 2013 - 07:00 PM
Hi:
The applink is working for i/o of the model, but when I import back to Maya, the textures are not included.
I have used both 'File/Open in original app', and 'export to Maya'. In both cases, an obj, mtl, and texture maps are saved to the 3DCoat folder. When I choose import, the obj is imported and deleted from the dir, so most of it seems to be working correctly.
In the video, you have a separate dialog for importing the textures, but I don't see that in the current version. I'm using Maya 2013, no SP.
Thanks.
#13 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 21 March 2013 - 06:30 PM
Ok guys. I just came back from vacation and ready to fix bugs.
Anthony Thomas
May I take a look hierarchy of your object? Will be nice to have a simple scene with the same object hierarchy that you used.
pixeldroid
thx for report, probably i found this broken place.
#14 Anthony Thomas
Anthony Thomas
    Newbie
  • 2 posts
Posted 21 March 2013 - 10:19 PM
Hey Neophyte,
Unfortunately I can't give you access to these files, as it is for a project under NDA. But if you feel it's a hierarchy issue, I can look through the hierarchy myself. What is it exactly I should be looking for?
Thanks!
#15 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 21 March 2013 - 11:20 PM
Yes, i don't need your NDA scene, but with similar hierarchy =)
#16 Lucoat
Lucoat
    Newbie
  • 8 posts
Posted 30 May 2013 - 11:59 PM
I dont know why, but its not working on maya2013 for me, no textures when imports from 3dc, on maya2012 works fine :blink:
#17 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 31 May 2013 - 12:39 AM
Could you take a look into ScriptEditor? Is any warning message there?
#18 Lucoat
Lucoat
    Newbie
  • 8 posts
Posted 31 May 2013 - 01:06 AM
No warnings:
coatImport();
file -import -type "OBJ" -ra true -options "mo=1" -pr -loadReferenceDepth "all" "F:/Docs/maya/projects/default/3dcoat/import.obj";
fileCmdCallback;
renameTextureViewPanel;
animationEditorFileCallback;
optionVar -exists dynPrefRunupToCurrentTime;
// Result: 1 //
optionVar -q dynPrefRunupToCurrentTime;
// Result: 0 //
proxyRefreshUI;
fileCmdRestoreCallback;
// Result: F:/Docs/maya/projects/default/3dcoat/import.obj //
Edited by Lucoat, 31 May 2013 - 01:09 AM.
#19 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 31 May 2013 - 01:52 AM
When you just load the plugin, what Maya says?
Smth like:
maya.exe path: D:/Autodesk/Maya2014/bin/maya.exe
user docs path: d:/Documents/
3dcoat maya dir: d:/Documents/3D-CoatV3/Exchange/Maya/
maya project dir: E:/Projects/MayaTestCases/
maya 3dcoat dir: E:/Projects/MayaTestCases/3dcoat/
Edited by Styler, 31 May 2013 - 01:52 AM.
#20 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 86 posts
  • Gender:Male
Posted 31 May 2013 - 01:59 AM
Hah.. It seems like a have the same problem with Maya 2014. I'll fix it. Thanks for bug reporting
