Houdini Applink
  • Please log in to reply
55 replies to this topic
#21 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 10 February 2011 - 07:56 PM
Yes, I need full access of obj-exporting, due to material-exporting and separation reasons too, and embedding some additional information, like slash-enabled sub-object paths.
Ah OK I see cool.
#22 revanimus
revanimus
    Newbie
  • 6 posts
Posted 31 March 2011 - 07:11 PM
Great to have this connection! Hope this will be further developed. I noticed a delay, when I am selecting the object to paint in Houdini. However, I am glad to have this plugin now!
"No man ever creates anything. He simply rearranges what's already here." --Hubert Laws
#23 revanimus
revanimus
    Newbie
  • 6 posts
Posted 31 March 2011 - 07:33 PM
Just got an error message when reimporting from 3dc:
Error running callback:
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
File "opdef:/Object/coat_file_out?PythonModule", line 137, in getback
KeyError: ('',)
#24 L'Ancien Regime
L'Ancien Regime
    Journeymen
  • PipPipPipPip
  • 1,335 posts
  • Gender:Male
Posted 03 May 2011 - 02:52 AM
Great stuff. Thanks a lot. You've got an attentive and appreciative audience over here..
#25 Nightwalker3d
Nightwalker3d
    Newbie
  • New Member
  • 4 posts
Posted 29 January 2012 - 05:35 PM
Under osx I get this error:
File "opdef:/Object/coat_file_out?PythonModule", line 385, in go
IOError: (13, 'Permission denied', '\\Users\\Cordeiro\\3D-CoatV3\\Exchange\\import.txt')
Any ideia how to fix it ?
Thanks
#26 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 27 June 2012 - 04:07 AM
This Applink only works on Windows because of the '/' being replaced by \\ (as I mentioned in a previous post)
You can easily fix it, edit the OTL, go to the Scripts page and at the very bottom of the code, put a hash (#) in front:
#fpath = fpath.replace('/','\\')
then it works fine :)
Andrew or BooBoo, I'm happy to fix this properly so it works on Windows or Mac/Linux. Works fine in H12 otherwise btw.
Cheers,
Peter B
#27 pbowmar
pbowmar
    Novice
  • PipPip
  • 150 posts
  • Gender:Male
Posted 27 June 2012 - 04:12 AM
Actually, sending the textures back to Houdini is also broken... And Ptex is busted, 3dc exports .exr files instead of .ptex
Using 3.7.12 latest on Linux
#28 bollili
bollili
    Newbie
  • 1 posts
Posted 06 August 2012 - 02:47 PM
Hi,
I'm trying out 3dc houdini applink the first time... and got stuck.
The handover from houdini to 3dc works for the geo but not for the textures. I checked the mtl-file via notepad: The two textures aren't generated in their desired location.
So I tried to put the original textures with the correct name into the folder, manually - problem persists, texture doesn't show up.
I tried with ptex paint, perpixel paint and microvertex paint. No luck at all to get the textures in 3dc... :(
Any hint?
Cheers
Marc
System: Win7-64Bit; Houdini 12.0.704; 3DC 3.7.08B(CUDA)(DX64)
#29 johnnycore
johnnycore
    Novice
  • PipPip
  • 286 posts
  • Gender:Male
  • Interests:Houdini
    C++
    C#
    Python
    Anatomy
    Rigging
Posted 11 August 2012 - 11:28 PM
I dont use the applink tool at all, feel more comfortable with importing/exporting manually.. :)
As for PTEX, its really easy to get it to work just create a surface shader node or modify a mantra surface shader node and drop in a Ptexture node and load in a .ptx file and it should be working correctly.
Also works great with displacement maps!
Johnny
Desktop: Intel core i7 2600k 4GHZ, nvidia GTX 560Ti 2048MB, 16GB DDR3 1333mhz, Windows 8 Beta x64 - Linux Fedora 18 x64
Sony VAIO Laptop - Intel core i5 520M 2,4GHZ, nvidia GT330M 1024MB, 8GB DDR 1333mhz, Windows 8 Beta x64 - Linux Fedora 18 x64
My youtube channel: http://www.youtube.c...ohnnycorebrieee
#30 Fake Pilot
Fake Pilot
    Newbie
  • 6 posts
  • Gender:Male
Posted 14 August 2012 - 02:30 PM
Hello. Is the applink between Houdini / 3D-Coat still not working correctly?
I tried it with the latest version of Houdini 12.1, couldn't get it to work. Hard to find good info too.
#31 subdproxy
subdproxy
    Newbie
  • New Member
  • 1 posts
  • Gender:Male
Posted 30 September 2012 - 04:05 PM
I like the 3D Coat Houdini App Link. It works great if I have nothing moving in my scene. Is there a way to turn off sending Geometry back to Houdini and just send the Texture maps? I noticed it removes all my Dynamic Functions (RBD) when re-importing into Houdini. The pivot seems to move on the object also. I like JohnnyCores idea of manually importing and exporting.
Glen
#32 sanchoflat
sanchoflat
    Neophyte
  • Pip
  • 24 posts
  • Gender:Male
  • Interests:NS
    houdini
Posted 09 January 2013 - 07:24 PM
Hm, I use H12.1 and have the same problem - when I try to export -
File "opdef:/Object/coat_file_out?PythonModule", line 361, in go
AttributeError: 'SopNode' object has no attribute 'worldTransform'
#33 Styler
Styler
    Neophyte
  • Applink Developer
  • Pip
  • 92 posts
  • Gender:Male
Posted 09 January 2013 - 07:48 PM
no sources, no fixes
#34 sanchoflat
sanchoflat
    Neophyte
  • Pip
  • 24 posts
  • Gender:Male
  • Interests:NS
    houdini
Posted 10 January 2013 - 07:05 AM
poorly. I have some question, maybe now you - why houdini dont render NM as well. I try to change my mantra surface, but result is terrible. UV map is good. In 3d coat and maya render was fine, in houdini.....
#35 Taros
Taros
    Expert
  • Moderator
  • PipPipPipPipPip
  • 2,988 posts
  • Gender:Male
  • Interests:Climbing, Photography
Posted 14 July 2013 - 07:34 PM
Important infos for AppLink users who have problems:
http://3d-coat.com/f...c=10198&p=96605
Best wishes
Chris
My tutorials on YouTube ----> http://www.youtube.c...raphicGladiator
My sculpting experiments on 3D-Coat.com ----> Take a look
My official website & blog ----> www.christoph-werner.de
My Twitter channel ----> @CWernerArt
My Download Shop ----> http://gumroad.com/Taros
#36 carlosan
carlosan
    Master
  • Custodian
  • PipPipPipPipPipPip
  • 5,411 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 08 August 2014 - 05:10 PM
Will be this applink compatible with the new
Houdini Indie ?
http://www.sidefx.co...=2853&Itemid=66
Side Effects Software, an industry leader in 3D animation and visual effects software, is proud to announce the immediate release of Houdini Indie which makes all of Houdini’s animation and VFX tools available under a limited commercial license to independent animators and game makers who want to use Houdini during the incubation stage of their business.
ty
  • ajz3d likes this
My Blogfolio
Google+ link
3DC Google+ Community
#37 TimmyZDesign
TimmyZDesign
    Journeymen
  • PipPipPipPip
  • 1,008 posts
  • Gender:Male
  • Interests:3D Generalist
Posted 08 August 2014 - 10:29 PM
Wow! Houdini Indie! So great! Really only $200? My mind is blown!
#38 Aabel
Aabel
    Neophyte
  • Pip
  • 36 posts
Posted 13 August 2014 - 03:31 AM
3d-Coat should go beyond app-link and integrate the Houdini Engine.
#39 ajz3d
ajz3d
    Expert
  • PipPipPipPipPip
  • 2,062 posts
  • Gender:Male
Posted 13 August 2014 - 03:27 PM
Fantastic news!
**** COMMODORE 64 BASIC V2 ****
64K RAM SYSTEM 38911 BYTES FREE
READY.
LOAD "DOODLES"
PRESS PLAY ON TAPE
SCRIPTS
3D-COAT MODERN DARK FORUM SKIN (STYLISH OVERRIDE)
#40 flipchord
flipchord
    Newbie
  • New Member
  • 2 posts
Posted 15 August 2015 - 12:13 AM
Hi Everyone - I am new to Houdini (bloody beginner level) and need some help with using the Applink.
I started my project in 3D-Coat and want to export it to Houdini.
Using Multiple UV-sets I somehow need to convert the sets to tiles on export - otherwhise they share the same 0-1 UV-space (--> attachment)
- Are there some "hidden" :)  export-Options I missed?
Since the Applink-Video seems to be down I need your help
Thanks Jörg
