3D-Coat 3.7 updates thread
1786 replies to this topic
#1041 Mykyl
Mykyl
    Novice
  • PipPip
  • 114 posts
Posted 17 May 2012 - 05:16 PM
Is there an issue with topo in the latest beta of 3dcoat on Mac? The mesh does not show up at all apart from around the edge of the model.
Screenshot attatched.
Ignore this. Just noticed I was not on the latest version. Its fine.
Mike
#1042 Garagarape
Garagarape
    Journeymen
  • PipPipPipPip
  • 1,206 posts
  • Gender:Male
Posted 18 May 2012 - 12:55 AM
Another minor bug on latest stable release (X64 wit Cuda).
When using reverse "Grow" in orthographic view to cut off voxel parts,
the model lighting changes just as if the source light was following the lasso (or square) selection.
Did someone else noticed?
It's not a crytical one at all, but that seems weird.
Cheers!
#1043 Vipera
Vipera
    Novice
  • PipPip
  • 116 posts
  • Gender:Male
Posted 18 May 2012 - 10:46 PM
When I try to decrease Spacing for brush tool using mouse in brush options I click on Spacing and drag mouse to the left. The Spacing number decrease to 10% then jump to 400%, decrease to 10%, jump to 400% and repeat loop. Is it bug or feature? I would prefer decreasing to 10% and stop. 3DC v3.7.11B
#1044 chingchong
chingchong
    Novice
  • PipPip
  • 469 posts
  • Gender:Male
Posted 18 May 2012 - 10:48 PM
Shader bug?
Watch on the video.
Buggy when switching to render room an rotate the object.
But when clicking on a shader in voxel room, then all is fine again.
with GL 64bit- version, latest beta, win7
#1045 geo_n
geo_n
    Apprentice
  • PipPipPip
  • 913 posts
  • Gender:Male
Posted 19 May 2012 - 04:34 AM
What is remove stretching? Where to find it.
#1046 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,589 posts
  • Gender:Male
Posted 19 May 2012 - 05:45 AM
It is a feature added a few versions ago. It automatically removes the stretching of the polygons in surface mode at the end of your stroke when using the regular surface mode brushes. LiveClay brushes by default have that setting enabled and I think the LC brushes do in it realtime if they are setup like the LC general brush is. You will not see the remove stretching selection box when using a LC brush.
Remove Stretching is located in the upper left hand corner of the interface when in surface mode using a regular surface mode brush. It is a selection box.
Also you will need "show beta tools" selected under the preferences menu.
If you do not see it then you need a newer beta...
#1047 geo_n
geo_n
    Apprentice
  • PipPipPip
  • 913 posts
  • Gender:Male
Posted 19 May 2012 - 01:28 PM
Thanks digman! Found the checkbox. The stroke is so smooth!
#1048 herve_bis
herve_bis
    Novice
  • PipPip
  • 253 posts
  • Gender:Male
Posted 20 May 2012 - 03:48 PM
In the last 11b, the clone tool in paint room is broken.... :(
h/
#1049 herve_bis
herve_bis
    Novice
  • PipPip
  • 253 posts
  • Gender:Male
Posted 21 May 2012 - 01:38 PM
recorded a small video... btw, the model is a retopo from voxels using Ptex.. (only one Ptex UV space)
http://screencast.com/t/X6DwUOLPEz0X
#1050 chingchong
chingchong
    Novice
  • PipPip
  • 469 posts
  • Gender:Male
Posted 21 May 2012 - 02:48 PM
Voice yourself ![/url]
wow, thats a realy old bug o_o
#1051 b33nine
b33nine
    Novice
  • PipPip
  • 179 posts
Posted 21 May 2012 - 06:53 PM
I'm getting very pixelated returns from projection painting in 3.7.11B. It's almost as if I only have a 1k texture space instead of the 4k texture space I'm working with.
#1052 Psmith
Psmith
    Helper
  • Moderator
  • PipPipPipPip
  • 1,124 posts
  • Gender:Male
Posted 22 May 2012 - 04:00 AM
Can you post a sample picture along with your machine specs?
Greg Smith
#1053 herve_bis
herve_bis
    Novice
  • PipPip
  • 253 posts
  • Gender:Male
Posted 22 May 2012 - 07:42 AM
sorry to quote myself, but is there a fix planned...? This is a rather big issue...
EDIT / I tested the same object with version 3.2.03, and the clone tool works perefctly and unlike 3.7.11b (which takes at least 2 min. ), when clicking the clone tool , it activates almost instantly.. so yes it is a bug.. at least looks like..
#1054 herve_bis
herve_bis
    Novice
  • PipPip
  • 253 posts
  • Gender:Male
Posted 22 May 2012 - 11:04 AM
oups... correcting the above.. wanted to say in vers. 3.7 (official latest) it works perfect.
h/
#1055 cl-apps
cl-apps
    Newbie
  • 19 posts
Posted 24 May 2012 - 01:42 PM
When are the mac people going to get there grubby mitts on the latest beta?
It seems the pc guys are having way too much fun!
#1056 artman
artman
    Expert
  • PipPipPipPipPip
  • 2,246 posts
  • Gender:Male
Posted 26 May 2012 - 05:06 AM
Not sure if this is something anyone else is noticing or if its a feature and not a bug but I've noticed that when I switch over to surface mode and do some sculpting then increase the resolution of the layer in the vox tree I lose all my sculpting from the surface tools?
To increase res in Surface mode do not use Inc Res button,instead use Resample option from voxel menu.
It is slower tough,on multimillion mesh it might take 2 or 3 minutes.
Lest limbs be reddened and rent--I spring the trap that is set--As I loose the snare you may glimpse me there--For surely you shall forget
"The Wind In the Willows", Chapter 7 "The Piper at the Gates Of Dawn"
#1057 LJB
LJB
    Journeymen
  • PipPipPipPip
  • 1,240 posts
  • Gender:Male
Posted 27 May 2012 - 12:09 AM
Also in that respect a toggle would be nice. B8kitano what about either flat shade or smooth shade with showing wire that would work best no? I find it most useful viewport shader in SI. I suggest cos we already have it in the paint room.
Posted Image
Check out my channel on vimeo Here
#1058 philnolan3d
philnolan3d
    Master
  • Moderator
  • PipPipPipPipPipPip
  • 6,544 posts
  • Gender:Male
Posted 27 May 2012 - 02:47 AM
I posted a feature request thread about 6 months ago with what I thought wires should look like
http://3d-coat.com/f...?showtopic=9143
Phil Nolan
Generalist
#1059 stusutcliffe
stusutcliffe
    Novice
  • PipPip
  • 443 posts
Posted 27 May 2012 - 11:50 AM
Just like Sculptris would be perfect!
#1060 geo_n
geo_n
    Apprentice
  • PipPipPip
  • 913 posts
  • Gender:Male
Posted 28 May 2012 - 11:05 AM
Speaking of viewport display. Ghostmode/fill/opacity display please for all rooms, material, object, layer.
http://3d-coat.com/f...?showtopic=9714
