Installing Cuda on Linux Ubuntu 12.04
  • Please log in to reply
5 replies to this topic
#1 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,589 posts
  • Gender:Male
Posted 02 June 2012 - 07:04 PM
I just upgraded to Ubuntu 12.04. I know there is a quide in the update section and I looked online on how to install cuda but somethings are not very clear. If anyone has installed cuda for 12.04, I'm all ears for any good tips...
Thanks in advance...
Reason more asking as I am looking to upgrading my video card to get enough cuda cores to really be a help in 3DCoat and rendering in Blender Cycles...
#2 renderdemon
renderdemon
    Novice
  • PipPip
  • 241 posts
  • Gender:Male
Posted 03 June 2012 - 01:54 PM
I can't help as I'm on ubuntu 11.04(I followed the instructions,downloading and installing cuda 3 if I remember well).
I answer you mainly because,as I spent some time in installing the cuda version,it doesn't worth.
I use it(as I installed the cuda library)but practically there isn't any difference between cuda and not cuda version(I have a 560 gtx ti),maybe with better/newer cards there are some advantages,but with such a card it's practically the same.
#3 carlosan
carlosan
    Master
  • Custodian
  • PipPipPipPipPipPip
  • 5,408 posts
  • Gender:Male
  • Interests:Character Design, Drawing, Sculpture, Modeling, Texture Paint.
Posted 03 June 2012 - 02:16 PM
http://sn0v.wordpres...n-ubuntu-12-04/
I hope this helps
My Blogfolio
Google+ link
3DC Google+ Community
#4 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,589 posts
  • Gender:Male
Posted 12 June 2012 - 02:16 AM
Ok, I got Cuda installed correctly about a week ago but alas my video card was too old. I went for a geforce 550 ti as it works with my power supply. In Linux, I just swapped out the cards (both Nvida).
Ubuntu 12.04 had no problems with that and Blender Cycles worked right away.
196 cuda cores and 2 gig of ram on the card. The 2 gig of ram will help in Cycles as it uses your video card ram for the scene/object textures and does not use your system ram.
The rendering speed of Blender Cycles is now very good... :D
Here is the video that did the trick for me using Ubuntu 12.04
Be sure to click the show more section as he puts in the commands for you to copy and paste into your linux terminal...
http://www.youtube.com/watch?v=GVUOxnpY2UA&feature=relmfu
Watch it at youtube to get the show more section.
#5 kurageart
kurageart
    Newbie
  • New Member
  • 1 posts
Posted 15 October 2012 - 05:03 PM
I struggled too with cuda in ubuntu 12.04, so, this is a very simple tip to help you:
DO NOT install blender from ubuntu repositories, just download the archive from blender.org ..
Untar and, voilà , cuda is working perfectly without having to mess with cuda developer toolkit - sdk etc
I have installed only the updated nvidia driver using the additional (restricted) drivers graphical tool...
Hope it helps...!
#6 digman
digman
    Expert
  • PipPipPipPipPip
  • 3,589 posts
  • Gender:Male
Posted 16 October 2012 - 08:32 AM
You must have installed cuda before. I don't think it is possible for blender 2.64 to install Cuda just by extracting the tar file. There are several steps you have to go through as the video pointed out plus I always download the current version from blender.org and test new builds from BuildBot.
Cuda started working most likely due to you updating your video card drivers that would work with cuda plus getting blender from blender.org.
I got cuda intstalled back in June, so I am good to go...
EDIT:
I could be miss reading your statement. Maybe what you meant was that blender from Ubuntu was the problem which I never used. The Cuda sdk, I did not download. I figured that if cuda worked in Blender Cycles then everything got installed correctly for cuda. I am been a happy camper enjoying Cycles. :D
