general:interface_navigation:help_menu
- This page description.
- 3DCoat Manual
- Suggest UI Text Changes
- Translate new texts: Translate new texts that were recently included into the 3DCoat or updated. Maximum 30 new texts shown.
- YouTube Channel
- Install plugin license (deprecated)
- Hotkeys & Sticky Keys: You may define a hotkey to almost any tool/action that you may perform via UI. To define a hotkey please hover your cursor over the required tool/action and press the “END” key. Then press the required keys combination. Keys can be specific for the current room or even a tool.
One key may be assigned to multiple actions or tools simultaneously (called "Stacked Keys"). Stacked Keys allow you to cycle through multiple tools with a single hotkey. If you defined a single action, tool or preset to a key, then you can use Sticky Keys. Pressing the key will activate tool and if you continue to hold it then release, it will activate the previous tool. In such a way you may temporarily activate some tool like freeze for example. With Sticky Keys, if you activate tool via hotkey and press the assigned key again, it will re-activate the previously used tool. Sticky keys does not work with Stacked Keys.\\
Other important possibility is to "change any text in 3D-Coat". Hover over any UI element and press "ALT+SHIFT+F9". Change the text and follow instructions.\\
- Upload Screenshot
- Upload Mesh to sketchfab.com: Upload your paint/voxel/retopo model model to sketchfab.com. In dependence on your current room the corresponding mesh will be uploaded.
- Upload Turntable
- Upload Turntable to YouTube
- Upload Turntable to Vimeo
- Render Turntables w/ Post Process
- Migration Master: This wizard will help you copy Alphas, Strips, Smart Materials, Stencils, 3B files from previous installation of 3DCoat to current one. Help move assets they may have created or accumulated, from previous versions of 3DCoat to a new version.
- Uninstall License: This option allows you to uninstall the license on this PC and install it on other. You can install 3DCoat on any number of PC's but you may not run it simultaneously on more than one PC at a time.
- Show My Key: Show key installation license .
- Language: Select your Language.
- Community: Link to 3DCoat Forum
Send File to support@3d-coat.com: This video covers a new feature that allows the user to send a large (up to 1GB) problem file directly to support@3D-Coat.com, from within the application…as well as mentioning other support options.
- Update Manager: Check if your version is the latest.
- About 3DCoat: Popup information about 3DCoat development team and community helpers.
Hotkey access to Brushes and Panels: This video demonstrates the ability to use hotkeys to bring panel's and pallets directly to your cursor and how to keep 3DCoat from switching to different brush packs when choosing a different brush or tool.
  • general/interface_navigation/help_menu.txt
  • Last modified: 2022/05/05 20:32
