general:modeling_workspace:add_geometry
Spine tool: The wire can be built by spinning faces around the axis or extrude along the spline.
Smart Extrude: Extrude faces in space with rotation and scaling without gizmo.
Move,Rotate, Scale without gizmo: Affine transformations (Move,Rotate, Scale) without gizmo.
Swept surface: Surface modeling with the profile and the guide.
Surface of Rotation: Rotate a profile around the axis to get a surface. You can use a curved axis too.
Polyhedron: Faceted surface of rotation.
Profile: Modeling of several profile types along the guideline.
Swept surface 2: Create surface with a profile and 2 or 3 guides.
Loft surface: Create a surface with N splines.
Swept surface N gener: Create a surface with N profiles and 2 guides.
Surface patch: Create a surface with splines serving as boundaries for this surface.
Surface by 2 views: Surface modeling with side and top views
Bevel N-segments:
Split Edges:
Weld Vertices:
Align Vertices:
Inset individual mode:
Poke faces:
Bevel Vertices:
Bridge:
Knife - Polygon cutout:
New 2D Primitives: Added new tool for creating 2D primitives for Modeling and Retopo rooms:
  • general/modeling_workspace/add_geometry.txt
  • Last modified: 2021/05/13 19:41
