general:paint_workspace:palettes
Create your own custom color palettes via the “Windows/Popups/Color Palette” menu. (you can assign a keyboard shortcut for this).
Right click on any color to Delete, Insert or Edit any color using the Color Picker.
New Color Palettes can be created and saved for later access - these are stored in the main 3DCoat folder, subfolder. “Palettes”.
Once stored, these palettes will always be available in the list - accessible through the “drop down arrow” menu.
NOTE: To disable the use of Color, as defined by the Color Swatches, Right click on the Color Swatch - and an “X” will appear over the Color Swatch, informing you that you are no longer influencing painting with these colors.
How to use the color palette: how to work with the color palette window. By Christoph Werner.
  • general/paint_workspace/palettes.txt
  • Last modified: 2019/10/08 12:00
