general:sculpt_workspace:surface_mode:clay_draw_2021
These are the “clay-like” tools that often parallel the same tools found in pure Voxel space.
Surface Brushes by Anton Tenitsky.
Clay: Surface Clay lets you quickly and fluidly apply mass to your voxel sculpture. The difference between this tool and the Carve brush is that it will also simultaneously smooth the surface after you’ve brushed it, giving it an authentic clay look.
Flatten surface and extrude using alpha and stencil. Edit brush parameters to set up the brush parameters in correspondence with your needs. You may duplicate the brush with RMB and create your own brush preset.
Clay Fast This is similar to the clay brush but works faster because there is no post-relaxing of the surface.
Draw: The Draw tool is great for quickly adding spontaneous detail, is great for sculpting horns, or anything else like that very quickly. It is similar to the the Airbrush tool, but it only operates on the surface of a volumetric object.
The draw tool is great for sculpting horns, or anything else like that very quickly. It is very much like the airbrush tool, however it only operates on the surface of a volumetric object. Use LMB to raise the area beneath the cursor. CTRL+LMB indents the surface, and SHIFT+LMB smooths the geometry.
Flatten: It flattens the area underneath your brush, based on brush size and intensity.
This mode flattens the surface beneath the cursor by raising or lowering points to a common plane based on brush size and intensity.
Height and angle are averaged from the point directly beneath the center of the cursor, and the effect is expanded to fill the entire cursor area.
Trim Adaptive
Flat Polish
Chisel: Similar to the Flatten tool, but it’s effect is less extreme and as you stroke along the object with your brush it will “chisel” away at the surface.
It works like scrape but dives into surface slightly. It is very handy for creating sharp edges. Use CTRL for inverse action.
Lute: This tool allows to fill cavities as if you are working with lute. Start to fill with lower pressure and end up with bigger one to get accurate result. Combine this tool with smoothing to get perfect result.
Fill: Surface Fill is a great way to fill in small voids, cavities and gaps in your objects. It is especially effective at very high settings.
Use CTRL to invert the action - to eliminate “embossing”.
Buildup: Similar in action to the “Build” tool found in the Voxel Room.
Behaves like the “Clay” tool, but builds the surface up without limits (not only one layer as with clay).
Extrude surface: Expands all vertices outward, uniformly, to a given radius along the surface under your brush, based on your pen Size, Depth and Extrude direction settings. At the top left of the interface are the Extrude Direction Settings. This allows for user definable extrusions.
These extrusion methods settings are unique to the following three tools:
Average normal, View direction, Along axis (X, Y or Z), Vertex normal & Initial vertex normal.
Change spacing to add alpha brushes along strokes.
Expand: Extrude surface along vertex normal direction.
Absolute: Extrudes the surface based on your Brush Size, Depth and Extrude direction settings, while also maintaining the underlying surface details and topology. Absolute extrusion relative to initial surface shape.
Rapid: This tool’s name is very descriptive, as it’s one of the fastest tools in 3DCoat to sculpt general shapes. It doesn’t respect Brush alphas but only brush Size and Intensity. Another great thing about this tool is that if you have two objects in the viewport that are separated from each other in space, it will try its best to form a bridge between them (welding them together as one object). It is very quick for rapid shape building.
Rapid Smooth Scratches: Provides a similar effect which clay sculptors use to “rough out” surface features quickly. Draw scratches along the stroke. Scratches will fade existing geometry as clay.
Simulates a real sculpting rake tool, creating scratches along the stroke. Great for creating muscle fibers and other similar looks. This tool does not respect brush Alphas. The difference between Scratches and Scratches2 is that Scratches2 smooths the edges of the brush stroke, while Scratches does not.
Mud: An interesting surface texture effect, providing rough edges. Very similar to Rapid, however this tool also has a noise parameter you can adjust to get variously bumped stroked, similar to quickly applying clay to a real sculpture without smoothing it with water get get that “mud” look. When you have more than one VoxTree object visible in the viewport, this tool will do it's best to sculpt on the current layer but will create volume as if it were sculpting on both as one layer. This tool does not respect brush Alphas.
Pinch: This is very great for making very nice tight edges, cavities and peaks. Surface Pinch is identical to the Voxel Pinch tool, but it is faster and only operates on the surface of a volumetric object.
This is very great for making very nice tight edges, cavities and peaks. You can better see that on the pictures below. It is identical to the Vox Pinch tool, however it only operations on the surface of a volumetric object. This option draws the surface area closer to the radial center of the cursor. Use CTRL to expand the surface outward from the center of the cursor.
Smart Pinch: Smart Pinch tries to pinch the surface toward to line picked, smartly. The tool picks two points - one on the left and one on the right side of the brush. Then it builds 2 planes from those points and snaps surface to the closest plane. Also it adds a little pinch to underestimate the sharpness of the angle.
Roof Pinch: tries to pinch the surface toward to line picked smartly. The difference with smart pinch is that this tool keeps the surface noise instead of flattening. The tool picks two points, one on the left and other on the right side of the brush. Then it builds 2 planes from tha point and pinches the surface to the planes intersection.
Shift: This tool drags the surface topology along with the brush. It’s great for producing wrinkles on a character or for making cloth. It is identical to the Vox Follow tool, but it only operates on the surface of a volumetric object.
Slides/drag geometric points of surface topology along the stroking motion relative to screen space with the brush. It’s great for producing wrinkles and so on the character or a creature or for making cloth. It is identical to the Vox Follow tool, however it only operations on the surface of a volumetric object.
Smooth: Produces much more dramatic smoothing than can be achieved with the standard Voxel equivalent. See also Tool Smoothing Options.
- Smooth Concave
- Smooth Convex
- Super Relax This is a powerful, valence-independent relax brush. It converts surface to the regular grid, relaxes, then bakes it back.
- Tangent
Sharpen
Freeze: A very useful masking tool, which allows you to define areas to be avoided by sculpting tools, or inverted to be the focus area for sculpting. The common shortcuts are “Ctrl+Shift+ I” (inverts your selection) and “Ctrl + D” (which deselects it).Freeze parts of the surface. Use CTRL+D to clear frozen parts, CTRL+SHIFT+I to invert freeze.
Surface hide: Works as a mask to hide a portion of the model’s surface mesh. Use the “Invert hide” option to hide everything but the masked area. Brush or use Stroke Draw mode to hide portions of the selected VoxTree object. To unhide, chose that option from the Geometry Menu.
Hide the polygons from being seen or edited by stroking over an area. All polygons will be hidden that are under your brush. After hiding some polygons, using the hotkey combinations CTRL+D will unhide and CTRL+SHIFT+I will invert the hidden polygons with the visible polygons.
Snake Clay
Copy Clay: This tool copies the surface areas. Point to the area you want to copy and click LMB. All that is within the diameter of the brush will be copied. Move the brush to the area where you want to apply the copy and click again LMB. If you want to copy a new area click “Clear Data”.
Magnify Layers: Magnify depth values based on previous brush strokes (up or down from the surface) on current Sculpt Layer. Found on Sculpt Layer version.
Erase Layers: Erase Depth values on current Sculpt Layer. Found on Sculpt Layer version.
Tutorials
The Dissolve Tool: This videos demonstrates the usage of the new Dissolve -Smoother- Tool, which allows the artist to paint select an area of the model and apply smoothing to it, quickly.
Quick Tip: Clean Surface Mesh: This video is a Quick Tip showing a few tools and methods to quickly clean up issues in Surface mode meshes, one may encounter on rare occasions.
Tangent Smoothing cleans on the fly without degrading surface details or shapes.
Powerful Smoothing also fixes holes or surface imperfections, but with much more aggressive smoothing.
Hitting the ENTER key in Surface mode will temporarily Voxelize and remesh the object, then return to surface mode, all in one quick step.
Improved Pinch Brush: This video demonstrates the improvements made to the Pinch Brush in Surface Mode Sculpting.
Subdivide Brush: This video demonstrates the new Subdivide brush.
The Angulator Brush: This video demonstrates the use of the new Angulator brush (Surface Mode only), that applies a pinching/creasing effect along the painted selection.
Lute Tool: This video demonstrates the usage of the new Lute brush; a new type of Fill brush in Surface mode sculpting.
Freeze Masks: This old video cover the creation and usage of freeze masks.
Reconstruct Smoothing Option: This video demonstrates the usage of the Reconstruct Smoothing Option among the SHIFT action and CTRL + SHIFT action menus, in Surface mode. It allows the user to dissolve stray pieces of a model much the same way Smoothing does when in Voxel mode.
  • general/sculpt_workspace/surface_mode/clay_draw_2021.txt
  • Last modified: 2022/06/14 14:52
