general:sculpt_workspace:surface_mode:custom_brush
- Principally new buildup mechanism for BrushEngine. Now buildup and non-buildup brushes act exactly the same, the difference starts when you will stroke the same place many times. Non-buildup reaches some height limit, buildup grows infinitely (but slowly) if the modifier allows.
- Brush Stroke
- Misc Settings: Principally new buildup mechanism for Clay Engine. Now buildup and non-buildup brushes act exactly the same, the difference starts when you will stroke the same place many times. Non-buildup reaches some height limit, buildup grows infinitely (but slowly) if the modifier allows.
- Sampling
- Modifiers
Base Brush: The basic brush for the voxel brushes. Duplicate, give the proper name and customize it. Press RMB and duplicate this brush to create the new brush.
Stitches: Stitches is the best tool to put stitches along the strokes. Chhoose stitches from the “Strips” panel. Use “Steady stroke” for the best result.
Add Brush: Create your own custom brush.
  • general/sculpt_workspace/surface_mode/custom_brush.txt
  • Last modified: 2022/06/14 14:56
