Surface Painting
Direct painting over surface models: Both diffuse color and glossiness intensity are supported. Just switch to the Paint Room and begin using color painting tools. This function is “on” by default. If you need to use regular painting methods (Per-Pixel, Micro-Vertex, etc.) - deselect “View/Show voxels in paint room”.
Polypaint allows painting on a model’s surface without first assigning a texture map. A texture map can be created at a later time, and the painted surface can be transferred to the map.
Once in Surface Mode, we really are dealing with a polygonal representation of a voxel object’s “skin”. Although
this skin represents a temporary condition of a model before it is ready for export, vertex colors can be applied to
this temporary, relatively high resolution mesh in the Paint Workspace.
To use the Paint Room tools for painting the diffuse color directly onto your Surface Mode mesh - simply click on
the Paint Room tab and start painting with the standard tools and Alphas with a single color - or use a “Material”
from the “Smart Materials Panel”.
If you have applied a Voxel Shader to your sculpture, the diffuse details from this shader will be combined with
whatever you paint in the Paint Room.
Make sure you have enabled “ShowVoxelsInPaintRoom” from the “View” menu to enable diffuse color painting.
All painting done in this manner is strictly temporary - in the sense that it is bound to the realm of 3DCoat, itself.
Once you use any method to “Bake” your model and its topology into the Paint Room, all these painted details will be baked into this permanent mesh as a diffuse texture map, which can then be exported along with your mesh.
Tutorials
Polypaint: This video is a feature demonstration of the Vertex Painting toolset.
Unique Sculpting Features: This video begins a series highlighting some of the unique features in 3DCoat that helps set it apart. It begins by showing how 3DCoat leverages PBR Texture Painting and High Poly Sculpting simultaneously…taking care of two normally time-consuming and tedious tasks at once and done rather quickly.
How to Import to Surface with (Image) Color: This video covers a quick tip about importing a model into 3DCoat's Sculpt Workspace, and having the color from a texture map baked into the vertices of the model, in the process.
Surface Paint: Exporting: This video continues the PolyPaint demonstration by covering an example of exporting the object directly from the Sculpt Room to a 3D application (3ds Max, in this case)…no UV's..no Retopo work.
Advantages of Vertex Painting: This video demonstrates some of the advantages of using Surface (Vertex) Paint, as opposed to the standard UV based texture painting tools.
Choosing Right Shader for Vertex Painting: This video briefly addresses a common question about Vertex Painting (why the user can't see their paint strokes, sometimes). And it's simply a matter of choosing right type of shader.
