general:sculpt_workspace:voxel_mode:clay_draw
This palette of tools on Voxel Room is an abbreviated version of the sculpting tools found in the Surface Mode.
Surface tools are modifying surface vertices instead of volume. This approach works much faster than voxel-based sculpting. But modification of the surface leads to polygon stretching, so if you feel that the surface is stretched too much press ENTER to apply changes and transform surface back to voxels.
In general we recommend that you click the letter “V” icon in the VoxTree and get to Surface mode (letter “S” icon). There is a much more powerful tool set for surface style modifications. See the Surface Mode descriptions in that section.
Surface Mode is much faster for sculpting than the regular volume mode. Only the surface mode tools will be available while editing in this mode, plus with the Pose, Move and Transform tools. Some of the surface tools have counter-parts from the volume sculpting tools.
There are a number of unique tools in this mode as well, which we shall discuss below:
Clay: Flatten surface and extrude using alpha and stencil. Edit brush parameters to set up the brush parameters in correspondence with your needs. You may duplicate the brush with RMB and create your own brush preset.
Clay Fast: This is similar to the clay brush but works faster because there is no post-relaxing of the surface.
Draw: The draw tool is great for sculpting horns, or anything else like that very quickly. It is very much like the airbrush tool, however it only operates on the surface of a volumetric object. Use LMB to raise the area beneath the cursor. CTRL+LMB indents the surface, and SHIFT+LMB smooths the geometry.
Flatten: This mode flattens the surface beneath the cursor by raising or lowering points to a common plane based on brush size and intensity. Height and angle are averaged from the point directly beneath the center of the cursor, and the effect is expanded to fill the entire cursor area.
Lute: This tool allows to fill cavities as if you are working with lute. Start to fill with lower pressure and end up with bigger one to get accurate result. Combine this tool with smoothing to get perfect result.
Trim Adaptive
Flat Polish
Chisel It works like scrape but dives into surface slightly. It is very handy for creating sharp edges. Use CTRL for inverse action.
Fill: Fill cavities. Use CTRL to invert the action - to eliminate “embossing”.
Lute This tool allows to fill cavities as if you are working with lute. Start to fill with lower pressure and end up with bigger one to get accurate result. Combine this tool with smoothing to get perfect result.
Buildup: Behaves like the “Clay” tool, but builds the surface up without limits (not only one layer as with clay).
Extrude: Extrude surface.
Expand: Extrude surface along vertex normal direction.
Absolute: Absolute extrusion - relative to initial surface shape.
Rapid: Very quick for rapid shape building.
Rapid Smooth
Scratches Draw scratches along the stroke. Scratches will fade existing geometry as clay.
Simulates a real sculpting rake tool, creating scratches along the stroke. Great for creating muscle fibers and other similar looks. This tool does not respect brush Alphas. The difference between Scratches and Scratches2 is that Scratches2 smooths the edges of the brush stroke, while Scratches does not.
Mud Very similar to Rapid, however this tool also has a noise parameter you can adjust to get variously bumped stroked, similar to quickly applying clay to a real sculpture without smoothing it with water get get that “mud” look. When you have more than one VoxTree object visible in the viewport, this tool will do it's best to sculpt on the current layer but will create volume as if it were sculpting on both as one layer. This tool does not respect brush Alphas. The difference between Mud and Mud2 is that Mud2 smooths the edges of the brush stroke, while Mud does not.
Pinch: This is very great for making very nice tight edges, cavities and peaks. You can better see that on the pictures below. It is identical to the Vox Pinch tool, however it only operations on the surface of a volumetric object. This option draws the surface area closer to the radial center of the cursor. Use CTRL to expand the surface outward from the center of the cursor.
Smart Pinch
Roof Pinch
Shift: This tool slides/drag geometric points of surface topology along the stroking motion relative to screen space with the brush. It’s great for producing wrinkles and so on the character or a creature or for making cloth. It is identical to the Vox Follow tool, however it only operations on the surface of a volumetric object.
Smooth: Smooth the surface.
Super relax: This is a powerful, valence-independent relax brush. It converts surface to the regular grid, relaxes, then bakes it back.
Smooth Concave
Smooth Convex
Tangent
Sharpen
Freeze: Freeze parts of the surface. Use CTRL+D to clear frozen parts, CTRL+SHIFT+I to invert freeze.
Surface Hide: Hide the polygons from being seen or edited by stroking over an area. All polygons will be hidden that are under your brush. After hiding some polygons, using the hotkey combinations CTRL+D will unhide and CTRL+SHIFT+I will invert the hidden polygons with the visible polygons.
Snake Clay
Copy Clay: This tool copies the surface areas. Point to the area you want to copy and click LMB. All that is within the diameter of the brush will be copied. Move the brush to the area where you want to apply the copy and click again LMB. If you want to copy a new area click “Clear Data”.
  • general/sculpt_workspace/voxel_mode/clay_draw.txt
  • Last modified: 2022/06/14 09:43
