general:sculpt_workspace:voxel_mode:commands
There are only a small number of commands in the sidebar, but they are all very important.
Res+: Use this to add voxel resolution only when you have exhausted the ability of the current resolution to add sufficient detail to your sculpture. Increase resolution. Increasing the resolution will effectively double the amount of voxels the current object layer has. This allows for a layer to have much more detail at higher resolutions. You can view the resolution of a layer, in the VoxTree, directly before the layer’s name. If it has just the name then you will know that it is at it’s base resolution and has not been increased.
Resample: This presents you with a dialog that allows you to adjust the resolution of your model “up or down”, as you require.
Clear: Will clear all voxel information from the current layer. This is useful for when you wish to keep the current layer’s name and resolution, but not the voxels.
Smooth all: Performs step smoothing of everything on the current voxel layer. Will uniformly smooth (or relax) all of the voxels of the currently selected object layer in the VoxTree.
  • general/sculpt_workspace/voxel_mode/commands.txt
  • Last modified: 2021/05/25 14:54
