All Activity
This stream auto-updates
  1. Today
  2. Hi Please show the texture UV editor and your export settings.
  3. Hello Is how it works, floating panels never are saved. Only docked panels position can be saved..
  4. Allabulle
    Blender 2.83 Applink
    Thanks, haikalle!
  5. haikalle
    GetBack button IsBack applink.zip
  6. Carlosan
    Hardware Reviews
    COUGAR DarkBlader-G Case Review - Neoseeker. Deepcool DQ850-M-V2L 850 W PSU review - Guru3D. Deepcool Gamer Storm Castle 280EX Liquid CPU Cooler Review - TechPowerUp. Dell XPS 15 9500 Laptop Review (2020) - MobileTechReview (video). EKSA E900 Pro Gaming Headset Review - ThinkComputers.org. Intel Core i9-10900 CPU Review - Fail at Stock, Impressive when Unlocked - TechPowerUp. Patriot PXD M.2 PCIE TYPE-C EXTERNAL SSD — Modders-Inc. Razer Huntsman Mini Review: 60% Gaming Keyboard With Optical Switches - Tom's Hardware. Roccat Kain 200 AIMO Gaming Mouse Review - AusGamers.com. Roccat Vulcan 120 AIMO Mechanical Keyboard Review - AusGamers.com.
  7. Carlosan
    Baking with a diffuse map
    Try Awesome Bump, is free AwesomeBump is a free and open source program written using Qt library designed to generate normal, height, specular or ambient occlusion, metallic, roughness textures from a single image. Hope it help.
  8. Carlosan
    Bug: carve tool is wrong vs 2D Paint tool
    Then please update me. - Carve tool is ok, it does not need changes. It only has to be inverted by default. - Carve tool > the brush has a completely changed behaviour from the previous versions. Is going to be replaced by 2dpaint tool. - Could please try the tool and tell me what it needs to be improved/modified to make it as functional as before the carve tool previous versions was ? Thx in advance
  9. Carlosan
    https://www.artstation.com/artwork/QrnnyE
  10. Carlosan
    3DCoat printing license commercial limits
    Hello Please contact sales@3dcoat.com Thx
  11. inache
    Hello. Tell me, please, is it possible to bake the normal map from the diffuse map?
  12. Hello, I wanted to ask you if the 3DCoat printing license is commercial to sell the .stl files For example, if I create a figure that I later want to sell, and then the person who buys it gives it another use than 3D printing. Would I be breaking the license, would the other person break it? Should I warn you when selling my .stl of what that person can or cannot do? Excuse me, I'm new.
  13. Allabulle
    Sometimes it's useful, yes.
  14. haikalle
    voxel scale issue Fiiinaaly fixed...knock the table applink.zip
  15. Innovine
    wow, so the current behavior is an improvement? Its totally insane to Carve in empty space. At least now its only backwards.
  16. haikalle
    Question for all applink user. Do you want "GetBack" button back?
  17. 3D-Coat doesn't save the workspace I've been using. On every startup it defaults back to the original. Kind of. There's an exception though. If I drag the tool panels on the right from their docked positions, they just kind of disappear. Same happens if I try to customize the UI. https://youtu.be/vRNQ1IoEiLA I've tried uninstalling and reinstalling. I've deleted the folders in Documents. Nothing works. This same behaviour has occured on 4.9.49 and now on 4.9.53 and this is starting to piss me off.
  18. Perfect ! I just changed the width of the texture so that it is twice the height (5000 x 10 000 pixels) Thank you very much for your help and your responsiveness
  19. Works great now. I foresee a lot of fun with this.
  20. Yesterday
  21. Well, I went back to version 9.38 and it works. Tenitsky's latest tutorial was made with 9.05 so we should be good to go. https://drive.google.com/drive/folders/0ByesnXO2ExYDREJkVHViV0ptX28 Take your pick, 9.38 or 9.39.
  22. nobackup
    I can confirm shift-smooth bugs out with the move brush.
  23. haikalle
    if object had more than one material they were messed up. Now that's fixed applink.zip
  24. Ascensi
    It happens exporting displacement textures sometimes in general. Try switching the Displacement types to something else then back again. You may just need to restart 3DCoat if it's more or other textures.
  1. Load more activity
