Posts
18 -
Joined
Last visited
Calendar
Gallery
Everything posted by splinetime
Andrew shouldn't have to respond to this kind of abuse! I have been with 3D coat a long time. This man is the most dedicated and responsive software developer I have ever seen. The program rocks. The scope is ambitious and software design is not click and drag. I appreciate the program, the development and you Andrew, and those who assist. Carry On!
No.... It feels orphaned.
Any love for the LW link?
The program is great. The documentation system is convoluted, confusing and separated by methods (PDF, web, videos) so as to just increase my frustration every time I try to get a thorough understanding of it. I truly appreciate the videos, but they are not a manual. A manual goes section by section. It addresses each item/tool, it details workflow. It can be used as a reference after going through it once over to look up tools, menus, commands and techniques. It has an appendix, glossary, table of contents, addresses all the programs features and their use. As they now function. It exists in one place. It's fine to append information for new features on a web site but it needs a sound foundation. Right now I feel stupid when trying to grasp the program. I think quality documentation is as important, if not more so, than the programs code. Am I the odd man out and everyone else just gets it, or are there others as lost as I am?. Thanks, Kevin L.
I agree about the 255,255,255 background....
First, after I got over the shock (had just visited yesterday) of the update. I have to say first impression is positive. Please warn next time a complete change is going to be made, as my mind immediately went to a hack as well. Rock On. Kevin L
Sorry for the delay. The .exe file shows 283,857,277 bytes (283,860,992 bytes on disk) When I double-click the corruption message. I tried using an unzip operation and that did extract it. I copied the files over the existing install and it "seems" to be working. I have had this issue with several of the builds. Thank You, Kevin
Greetings, I'm double posting this (as a pointer to the original post in "New Users") I am inquiring as to the proper folder topology. I do not know if my extensions are all in the correct spots, if I need to do something in the program or folder structure. I made a "Fresh install vs. extensions added" pdf. Any guidance would be welcome. Folder Outline-extensions Added_3D-CoatV4.pdf
I bit the bullet and went ahead, did a clean install and printed the folder structure. Then I installed extensions and printed that. I have it in a PDF. One thing I notice in my clean install vs. adding extensions is that the extensions all installed in the "user" folders, not "programs". This made sense. It also was not like the mess I originally had after doing multiple updates installs. I have attached the pdf, with basic bookmarks. One question: Should extensions be installing in the root "user/documents/3D coat-v4" or should they be in the different sub-folders i.e. textures, patterns.... Kevin L Folder Outline-extensions Added_3D-CoatV4.pdf
Thank You for responding. I am familar with the idea of clean installs. I prefer to understand the structure so I can fix problems and customize without breaking things that are working. I had downloaded a number of penpacks and shaders, etc.... and now I have parts and pieces all over the place. Kevin L
At least I'm not the only one
Greetings, I posted about this in the New User forum, and so far no reponse. One thing I find terribly confusing is the what goes where. [Folder logic] I understand the idea that the user folder is now where we should store data, but do I pull stuff out of the "program" location (pens, textures..), leave it there.... etc I have a boatload of stuff (textures, penpacks, etc...) in my User..../3D Coat folder, that I have no idea where it came from and where (or if) I should move it. Also preference and config. info It would be truly helpful to have a layout and description of which folders should have what. Where they are located and how to manage them. I know it is dry stuff, but right now I am trying to learn this program and I am certain some of the issues are related to fouled up locations. Are there any existing documentaions of this (I've Googled myself silly: EDIT: I meant to say User.../3D Coat/Layout folder
As is mine in the program folder.
As I am digging through tutorials and manual, exploring the topology of 3D Coat I have found a perfect example of my confusion. This is in my Documents/Layout folder. I suspect some of these are incorrect.... but? Any help appreciated, thanks in Advance. ...\Documents\3D-CoatV4\Layouts Bluegrey_Depth 6/13/2013 Brush' n Voxel Stamps obj.'s 6/14/2013 Bugreport 7/31/2013 Cache 6/30/2013 Eat 3D - 110 Custom Bolt Alphas 6/14/2013 Extra 6/14/2013 FillPatterns 7/29/2013 Gold 6/14/2013 HardSurface alphas 6/14/2013 J_Bone_001 6/14/2013 J_BoneBump 6/14/2013 J_Chocolate 6/14/2013 J_Eye_Blue 6/14/2013 J_LizEye_001 6/14/2013 J_LizEye_002 6/14/2013 J_Skin_001 6/14/2013 Layouts Today Oldwood 6/14/2013 OptionsPresets 6/14/2013 OT_Mech_Details 6/14/2013 OT_Sculpting 6/14/2013 patterns 6/14/2013 PicMat_Dorodango 6/14/2013 RenderedImages 6/17/2013 Shaders 6/13/2013 SN_Metal_Bronze_Brushed 6/14/2013 StartMenu 6/14/2013 Temp Today textures 7/29/2013 ToolsPresets 6/16/2013 Undo Today UserData Today VoxStamps 6/13/2013 XMD_Clothing_Set1_Alphas 6/14/2013 XMD_Drag_Brushes_Set1_Alphas 6/14/2013 XMD_Gear_Set1_Alphas 6/14/2013 XMD_Nature_Set1_Alphas 6/14/2013 XMD_Skin_and_Wrinkle_Set1_Alphas 6/14/2013 XMD_Stroke_Brushes_Set2_Alphas 6/14/2013 XMD_Tech_Set1_Alphas 6/14/2013 XMD_Terra_Set1_Alphas 6/14/2013 artman's HardSurface.preset preset 6/14/2013 artman's presets 1.4.preset preset 6/14/2013 basehead01.3b 3b 6/14/2013 Bluegrey_Depth_shader.3dcpack 3dcpack 6/14/2013 Eat3d_110_Custom_Bolt_Alphas.jpg jpg 6/14/2013 Eat3d_110_Custom_Bolt_Alphas_Render.jpg jpg 6/14/2013 Hair_V1.penpack penpack 6/14/2013 HardSurface.psd psd 6/14/2013 Hardsurface Penpack.penpack penpack 6/14/2013 KTL_Voxel 061313.onepagelayout onep... 6/13/2013 LOAD THIS PENPACK FIRST.penpack penpack 6/14/2013 Log.txt txt Today Options.xml xml Today Options_Aux.xml xml Today Options_Hidden.xml xml Today Options_Hotkeys.xml xml Today Options_Navigation.xml xml Today Options_Presets.xml xml Today Options_Theme.xml xml Today Options_Windows.xml xml Today OT_pack.txt txt 6/14/2013 Presets.xml xml Today process.txt txt Today rparam.xml xml 6/17/2013 temp.txt txt Today test_raw.mtl mtl 7/31/2013 test_raw.obj obj 7/31/2013 TinkerObjects.txt txt 6/13/2013 UnknownShaders.txt txt Today Voxel Room_General.3dc_workspace 3dc_... Today window.txt txt Today XMD_ClothingSet1.penpack penpack 6/14/2013 XMD_Drag_Brushes.penpack penpack 6/14/2013 XMD_GearSet1.penpack penpack 6/14/2013 XMD_NatureSet1.penpack penpack 6/14/2013 XMD_SkinWrinkle1.penpack penpack 6/14/2013 XMD_StrokeBrushes.penpack penpack 6/14/2013 XMD_StrokeBrushes2.penpack penpack 6/14/2013 XMD_TechSet1.penpack penpack 6/14/2013 XMD_TerraSet1.penpack
Greetings, I have been trying to dig into the logic behind folders (brushes, materials, etc) so I know where things go, backup or can group differently, etc. Is there a straightforward outline of what goes where and where those folders are? I feel confused. Thank You, Kevin L
