herve_bis
Advanced Member
  • Joined
  • Last visited
Everything posted by herve_bis
  1. Hello.. thank you I used Reality Capture for the 3D scan
  2. yes the base was a 3D scan
  3. Used 3D Coat for retopo and maps. Rendered in Maxwell
  4. hellooo.. Thanks a lot Digman... I will definitly try your workflow. h/
  5. hey Thank you.. well I was just curious if it would keep somehow the Uv's .. all I needed was to import a scanned model in sculpt room , do a bit of smoothing and then re-export like it was.. with its UV's.. h/
  6. Hello, I have imported in the sculpt room a mesh with uv's and a map It was just to smooth some areas.. but now when I try to re-export it... it has lost it's UV.. Is there a way to export it with its UV..? I also could not find in the docs (might be hidden) wht is exactly the Use of Import UV and Export UV in the paint room TY h/
  7. well in a way we do have VD.. but what would be very useful is to be able to bake a VD on a retopo mesh From the Sculpt room.. ah well..
  8. hello There I think we need Vector disp baking in 3D coat.. That would be a must, we could also simplify our retopo meshes when there are lots of nooks and crannies.. thank you for considering it. h/
  9. yes... it is essential if you want to retopo a color mapped scan.. vertex color is nice but not as good as a map. cheers.
  10. thanks but vertex painting was not what I needed.. only the high res with its UV and the color map.. I found that LWO is the answer. imported as voxels (with Import W/O voxelisation clicked ON... Works like a charm ! thanks
  11. hello.. I have a scan with some uv's and a color texture. Now I simply want to import it to 3D coat, then do a AUTOPO to get a low polys mesh, make some UVs, and then Bake a disp + color texture. Is it possible..? I have no luck so far.. when I import my scan (8 millions polys) in sculpt room, I get no texture, only geometry.. making it useless.. Thank you
  12. mmm Thanks Taros.. maybe I moved it accidentaly, but I doubt.. I will test more today
  13. kk.. there is a bug... when I load a mesh as voxels.. 3D coat asks me if I want to keep position and scale.. Scale is kept, but position has changed !!!! please fix asap. thank you
  14. HELLO I am going crazy over that bug... never ever had that in years ! ! basically I have one single layer. an Object I have retopoed, UV.. then I baked it to the paint room using Micro Vertex.. It shows very well in Paint room. If I set the depth to 0%, I get the perfect retopo mesh.. If I set the layer depth to 100 % , I do get the nice disp. Now... if I output the disp... It's all wrong... all I get is a very smooth shit ... the disp is just not there.. If I output a Normal map.. all perfect, but I want a disp, not a normal map... Dang... sorry I can't post anything... so I guess there will be no help... ah well... shit happen Maybe I'll just drop 3d coat and move over ZBrush... as I have no other solution.. too bad, it was a nice app.. but Way too buggy...
  15. hello, I made a small tutorial for people using 3D coat to fix and prepare their Scans done with Agisoft Pscan, mainly for hollowing the model. in case some people are interested.. (scroll down the page ) http://www.agisoft.ru/forum/index.php?topic=2282.0 bye f/
  16. Hello... I would like to create some bubbles on a mesh surface, but I don't want the bubbles to be part of that object surface.. is there any way to draw bubbles on a seperate layer... if I add a layer, then it draws nothing.. any idea..? thank you
  17. hello... I am using the last stable build.. 4.0.04B BOXX dual xeon E5 2687W @3.1ghz - 128gb - win7 64bits I try to load a scanned object with only 15 millions polys... I tried the cuda and DX versions.. both crash.. It first read the obj. file, then I see the import mesh panel, click apply.. crash.. I have had that same issue in the past where anything above 5 millions obj. would crash, apparently still the case.. is there any plan to fix it one day..? h/
  18. Hey Tony thank you... yes that is what I did til now.... I Will try the noisy mask... h/
  19. hello, is there any tool or procedural I could use in 3D caot voxels to model some clouds..<?? thank you h/
