Posts
135 -
Joined
Last visited
Calendar
Gallery
Everything posted by Britain
There either an issue with 3dcoat or the app. Hard surface modeling with bevels or edge loops breaks the smart materials with edge detect in some instances. The pictures are of a simple object with one boolean cut. Adding a small bevel to all edges breaks the edge detect. With No bevel theres no edge detect. Add one bevel and there edge detect on all edges. Add a edge loop cut breaks the smart material. I havent determine why this happens.
After using the app for a few years I also lost the ability to export to. Out of nowhere it disappeared from the 3dcoat program. No upgrade to any OS or programs were done when this happened. Im still on widows 7. Did the usual trouble shooting install fresh 3dcoat and Blender and still no menu to export to. Luckily the Open in original app (3dcoat) still works so I can still use the program with out the trouble of setting up the nodes in Blender. Currently only using 3dcoat for texturing and painting. Though open in original app needs the correct folder address with only the newest current work loaded into it for Blender to read correctly.
Thanks, Didn't know your were the creator.
Wheres the latest link for the applink? Thanks
The Nikon P900 Superzoom- $599
Britain replied to L'Ancien Regime's topic in CG & Hardware Discussion
Interesting. But only shoots in .jpg. From what can be read all the zoom is crushing in the .jpg -
Wow Blender Asset Managment app
Wont replace SW. If I was to send in a Blender using Hard Ops model for quoting I'd get laughed out the door. Hard Ops is pretty cool though. -
Darktable - open source photography workflow application
Britain replied to Carlosan's topic in CG & Hardware Discussion
Yes I did. Good program. Close to Lightroom. -
Wow nice! Found a windows version. Thanks for sharing! -
I also felt it was to bright. Reverted to the old 3Dcoat at bottom change theme.....
V4.5 BETA (experimental)
Britain replied to Andrew Shpagin's topic in New Releases, Bugs Reports & Development Discussion
Missing split tool in voxel, its in surface. DX ,GL and and associated Cuda -
Blender Applink "Simple3DCoat" (Fork of the official) by mifth
Britain replied to mifth's topic in 3DCoat AppLinks
Yes the paint works need to refresh a few times.- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
@ mifth There could be other painting imports ( per pixel painting for one) crashing 3dcoat also. Carlosan would know more on the changes. Real cool Miratool and mifthtool thanks for those! umm per pixel painting started working.....- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
The app is using an older 3dcoat retopo. The newer 3dcoat has an option for hard surface retopo. The retopo either needs to be fixed or removed from the app.- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
It appears to be pulling up an older Retopology. There also is no option for Hardsurface Retopology. It is referencing and older 3Dcoat version.- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
Using Blender 2.75A , 3DCOAT 4.5.07 Mesh for Auto retopology crashes 3DCoat.- 153 replies
- export
- 3dcoatapplink
(and 3 more)
Tagged with:
Updated BIO's and Nvidia drivers, all is good. Thanks
DX side is working the GL is not. Let me trouble shoot the video card.
Only the logo comes up then hangs. Dell Precision 64bit windows 7.
Changed out failed mother board now V3 and V4 no long work. How to fix?
How do you get the standard PBR materials to show? All I have is close and new. -
Andrews quick updates!
Who uses Blender here at the 3DC forums
Britain replied to digman's topic in CG & Hardware Discussion
Perhaps its time for the Prometheus contest. -
Traveling with hard drives - metal detectors
Been back and forth from Italy. Germany and Japan no issues with a Dell lap -
Yes one was scale! Thanks for the tip!
Had some time to spend on the burning of the exr. Not as good as yours actually not really good at all but it did work. Need more practice there.
