vivi
Advanced Member-
Posts
156 -
Joined
Last visited
Calendar
Gallery
Everything posted by vivi
I suggest to have an align function for the merge tool. Basically like the on pen function but as a klick and place/align function. And this toolbar also has way too many buttons.
How can I import a polypainted OBJ from Zbrush for texture bake?
vivi replied to Bumper's topic in General 3DCoat
Excuse me? what was that about bad mouthing? Just said 3dCoat can read polypaint...why dont u relax. And with "you got the point" I just just agreed that we should try to stay in one software to avoid problems. -
3dcoat imports the polypaint automatically...it should be there right after importing it. But of course only if u dont voxelize it. 3dcoat can do vertex/polypainting. u got the point -
u wrote pixologic to redesign their UI? just get used to it...at least Zbrush works like a charm! I'd rather have that confusing UI with good results, then good UI and bad results. 3D coat in my opinion does have none yet. But I am not blaming Andrew. Pixologic just have the money and manpower. In that respect Andrew is doing a greater job. And even though I am liking 3D coat..in Production it always disappoints me, Zbrush...not
under export texture , there is no tiff available...only if i export the whole model....nor does it say 32bit
What about Normalmaps? When I export them I get an 8bit Normalmap
How to use that Mantis? where do I post something?
this is not a solution...I am faster doing that in 3dsmax. The point is I have MANY islands...small parts..now I have to tweak some...so guessing where my related island are..is too time consuming. I would give this feature request a +1
basically I wanna select my UV island in the viewport. Because selecting in the UV window is very tiresome since its hard to locate my islands. Is there a way to select them? vito
Thanks heaps!
Hey guys.. 2days ago I was testing retopo in 3Dcoat and it worked pretty well. Today with the same model..it doesnt. I dont know why but suddenly when I am in the reotopo curve draw mode...drawing seems pretty slow and if I draw a closed circle nothing happens ( only a dot is left ). No curve at all. I tried cranking up the spline density but no effect. As I said , 2 days ago the same model worked like a charm! The workflow is : -model in zbrush -export and import in 3Dcoat -I import as " do not voxelize". -If I dont do "Autoscale the mesh will be very small but the Voxel Layer will have a resolution of 74x which makes the retopo useless. -If I do Autoscale, the VoxelLayer res is at 0.5 and the retopo works fine. I can't use autoscale since this is random right? so a no-go for every pipeline can somebody explain how this works? thanks in advance Vito
when I try to import FBX into 3dcoat I get a crash! Will Vertex Colors be exported automatically? Do I need to check somethings in the exporter?
hi guys..I was wondering how to import/export vertex colors. I am trying to export a vertex color painted mesh from 3dsMax into 3Dcoat. I think the problem happens on export side though. When I check by re-importing my obj back into 3dsmax it doesn't contain vertex-colors anymore. Maybe someone tried it before? Vito
what is the problem?
When I use closed curve, the first point and the last point, is kinda producing strange result. I t looks like the spline is not closed correctly... http://bit.ly/xUfu9X
Excuse me, it's not about liking or not...it's business ! And if you don't play by the rules, then u gonna be knocked out..even u were first! I am not sure if Andrew did get patents on his technology, if not then I think it was very careless. In this world u need to protect just about anything, otherwise it will be taken by others. "Business"...who gives a damn about you?? They just steal it from you..even if it would mean that u'd have to live under the bridge.
No opinions?? dissapointing!
I have made this video to show what I think would be a very cool feature and work-flow in 3D-coat! Notice how flexible this work-flow is... This is what is still missing in 3D coat! Flexibility!! This is not about rooftops..it is about work-flow. If 3D coat could do this..then it could do many other crazy things, even Z-brush would not be able to do. The point is to stay flexible. As you see in the video, I was able to change almost everything at any stage, while progressing. I can go crazy, and be creative and just keep adding details..and still I can go back and change the roof tiles completely. This is power!! What you see here could be applied to totally other things. like a knights armor, or for some fancy curved spaceships etc. The possibilities would be maybe endless? I tried modeling the same in 3D-coat..it was actually cool to use the curve tool. but yeah voxel..once laid down..u have to stick to it. Yet, what u see is just made with the tools I had...no scripting. If I were able and smart enough to script..I would be able to go even more crazy!! I hope u find this interesting, and that 3D-coat goes more towards efficiency, flexibility !! It is what matters in production. Where is the point if u have some kick-ass stuff, but the client wants to change something..then u are literally screwed.
no, other brushes work fine...it is only the grow brush
ah..sorry about spreading my posts around..didnt think about that... I tried to help anyway...that's why I thought I record videos, since I am not good with words.....and most of the bugs I can't reproduce..since some of them happen out of nowhere. And I think in most videos u can see enough... I also explained when it happen..not always though... but it's fine..no need to start a drama here..I am gonna shut up!
