Posts
260 -
Joined
Last visited
Calendar
Gallery
Posts posted by Cleitus
22 hours ago, Carlosan said:
Вы можете разделить кривые и тащить точки с помощью ЛКМ
Как это сделать? Перетаскивать с помощью ЛКМ могу, но разделить кривую не получается.
Здравствуйте
Подскажите, как добавить и разделить кривые как показано ниже. Из-за плохого Английского, по видео ничего не понятно.
3 hours ago, popwfx said:
Just tried to download an install 4.8 on Win 7
3d-Coat-V4_8-03-64.exe
and when I run the exe it gives an error: "Installer integrity check"? Any trick needed? I tried downloading a few times in case it was a corrupt download to no avail. I'm getting the size as 326,240 KB - is that right?
(also forums are acting a little weird where clicks don't work - I've always used firefox and this is new - is there a problem currently?)
The forum is buggy, I agree
The problem was that _DIFFUSE texture is created in black.
Here is the texture. 6511C076_DIFFUSE.rar
When you add new environment map to all of color become black
standart
added: last in the list at the bottom
but the shadows are turned on everything is fine
You are welcome!
You can adjust the degree of sticking of the cursor to a 2D grid, very low level of adhesion?
Thank you! Glad this helped you.
- 2
From what I've heard, work on the program not so many people. If so, then I think the realisation of such novelty can really take a lot of time and effort.
But still it would be nice to see it in 3Dc.
I agree with you. On account of the groupings of instruments would be nice. I also did a request to add a procedural filters for materials. But I think it's better to discuss it here on the forum, because some may not agree. But if Andrew thinks this is correct, then I think he can add these innovations into the program.
And why all this time I didn't pay attention to the radial symmetry
Thank you. Topic can be closed
There is an idea to make a tool to squeeze in the form of a cylinder, sphere, cube or plane with the ability to transform, the similarity of the 2d mesh. And each grid square, for example of the cylinder will be squeezed out in the shape of the brush.
For example, you can make this form of the model without resorting to other 3d programs.
(Есть идея сделать инструмент, который будет выдавливать по форме цилиндра, сферы, куба или плоскости с возможностью трансформировать, на подобие 2d сетки. И каждый квадрат сетки, например цилиндра будет выдавливать по форме кисти.
Например можно сделать такую форму модели не прибегая к другим 3d программам)
- 1
You are welcome! I will share all that I find useful
- 5
Прошу прощения, что пишу на Русском. Хочу описать проблемы с которыми я сталкивался.
1 Это проблема с качеством карты нормалей на ровных местах при bake.
2 При перезапуске сцены на воксельных слоях появляются деревянные признаки и при сглаживании они становятся жоще
3 Проблема при bake сцены с оптимизированными surface слоями, появляются такие признаки
[Solved] Как соединить или разделить кривую ?
in 3d Coat
Posted · Edited by Cleitus
Спасибо. Буду пользоваться новой версией кривых.
Решил проблему сохранением кривой и загрузкой в новую версию кривых. Там его можно спокойно разделить и загрузить обратно.
